Shifting difficulty, looking for opinions
However, after reassembling everything with the new master / slave. The shifting problems continue. So, I figure it's only 2 possible problems left, the synchros, or the shift forks. I wanted to see what other people though. The problem is sometimes (more often than not) it is really hard to shift into first or second gear, as well as 5th and 6th. It feels like it shifts into place, but then if you let off the clutch you just get a lot of grinding. If holding pressure against the shifter while slowly letting off the clutch, it will sometimes clunk into place. Double clutching also seems to help.
I was going to swap the transmission as well while I had everything apart (found one that has 44k miles on it for a good deal, cheaper than having mine rebuilt, and for reference mine has 160k miles :p), but ran into delays with that being available and had to get the car back together for now. So, I do also have 4 quarts of gear oil, and I'm debating if I should drain the fluid in the current transmission and put that in there, or if it would just be a waste of fluid. I still might get the other transmission, just not sure when, nor if I'm ready to do this job again any time soon lol. While dropping the rear wasn't really hard, it is tedious, and not something I can do alone, so relying on others to have time to help means the car may be down for too long and I've got to try to find a time that I'm ok with it being down for multiple weeks (I generally can only get help on the weekends when I'm able to get it). And taking it to a shop is an iffy option, I don't really trust shops to do stuff right, haven't been able to find one that is just constantly in a rush to get the job done and careless since it's not their personal cars. Not to mention just because this job is so tedious, it's way more expensive than what I want to pay someone else to do it lol. But I do understand the cost, it takes a lot more hours of labor than a general transmission swap, just more than I want to pay right now.
But, like I said, I wanted to see what others thought. Does this sound like synchros for sure? Or is there a chance that changing out the gear oil would help? If there is not really any chance changing the gear oil will help I won't waste it and will just wait until I either get the transmission rebuilt or swap another transmission in.
Usually there aren't really shift fork issues with these transmissions except for 3/4 because they used an aluminum 3/4 shift fork - but that can be upgraded to iron/steel. Shift rails aren't likely to be an issue either, assuming you can get into each of the shift gates without issue. So that kind of leaves component(s) within the synchro assemblies as the culprit... From my own experience getting grinding in 1st and reverse that was somewhat similar to yours, it's likely something to do with synchros. You won't know for sure until cracking into the trans, of course.
There's also a drill mod for the master and slave. 1 orifice for the master, 2 for the slave but supposedly you can only reach the one because of the factory bend in the line.
I also feel like if it was an alignment issue, the shifter wouldn't click into gear sometimes while keeping force on it and lifting on the clutch pedal.
I also feel like if it was an alignment issue, the shifter wouldn't click into gear sometimes while keeping force on it and lifting on the clutch pedal.On the note of the MGW shifter though, it does have a nice short throw and feels nice and smooth... but damn it's heavy to go over to 1/2 or 5/6. Not sure I like that aspect of it.
Obviously, I can't attribute the result to one or the other – it was probably a combination, but probably most likely primarily related to clutch hydraulics – but, in any case, I'd certainly try a comparatively inexpensive fluid change first. It's easy, too. I had similar success in my old Subaru Forester with just a fluid change; a blend of new high-end fluids cured its reluctance to engage first at slow speeds and when cold, and greatly improved the action of the gearbox point blank (and it stayed that way for 12,000 miles, until I sold it).
The only step I need to take now in my C5 is to remove the original shifter tower (its bushings are a bit tired) and the aftermarket Hurst shifter, for similar reasons that you describe. The horizontal effort's a bit excessive and, in my shifter, its centering is a bit odd, all of which exacerbates any shifting-related issues. I've got a new C6 Z06 tower and shifter to go back in, which should hopefully serve up a decent middle ground.
Yeah, I bought a MGW at one point and wound up selling it with this being one of the main reasons. Heavy left/right motion on the shifter sucks for daily driving, and unfortunately the anti-venom mod only affects fore/aft motion. I went back to C6 + TMOD lower box, and recently shortened my C6 shifter for a little extra improvement.
Seems really odd to me that this happens with the clutch pedal fully depressed.
When the clutch pedal is out, the clutch, propeller shaft, and transmission input shaft are all spinning at engine speed and therefore have momentum. When you depress the clutch pedal, [assuming the clutch fully releases] all of the previously-mentioned components will begin slowing down, though I have no idea how long it takes for them to stop spinning.
One of the jobs of a synchronizer is to use its friction material to make the transmission input shaft match the output shaft based on which gear the trans is in. When entering reverse with zero wheel speed, the reverse synchro will brake the trans input shaft as reverse gear engages. So, perhaps when you're entering reverse the transmission input shaft is still spinning a little and the brief jerk you feel is simply the input shaft having speed and then decelerating from reverse engagement. Could be that the reverse synchro ring no longer can impart enough friction to adequately brake the input shaft... it's just brass after all and could be worn; all the other gears use a proper friction material on their synchros. (fun fact, you can replace the brass reverse synchro ring with one from 5/6 gear)
There's also the possibility that the clutch isn't 100% disengaging, which could allow the trans input shaft to have extra speed during reverse gear (or any gear) engagement. This is kinda what it sounds like, assuming the clutch pedal is depressed the whole time for when you mention going back into neutral and reverse. In neutral there's nothing in the trans preventing the input shaft from spinning up again.
You can minimize this behavior in reverse by first going into a different gear (which uses that gear's synchro to brake the trans input shaft), and then go into reverse.
