Change water pump yourself?
Old Aug 27, 2022 | 12:32 AM
jim993's Avatar
jim993
Keeping the gaskets in place while you install the new pump is easy, just put two rubber bands on two of the bolts on each side of the engine side of the water pump, holding the gaskets in place against the new pump until you get a couple of turns on the bolts, then cut and remove the rubber bands, torque per FSM.
