My 2003 coupe needs a new water pump at 131k. I’ve got a new AC Delhi pump and a set of jack stands. I’ve read the procedure and it doesn’t look all that complicated.
Any experience/insight doing it yourself with no lift, just jack stands? Understood you don’t need to jack it up to actually change the pump; thinking more about getting underneath to drain the coolant.
Hardest part was getting the old gaskets off block. Lucky found a razor and they came off. If you plan the change thermostat at this time (160?) this woulb be the time. It should be a thermostat by itself not one built into the neck housing. Also check any hoses if they need to be replaced.
Only use Dex cool antifreeze.
I think I ran my car up on ramps to give me room for stuff I am going to drop under the car.
Just had mine off to change the A/C compressor. Make sure you get the reusable gaskets, makes thing much easier next time you have to go in to do something that requires removing the water pump.
I just changed mine out when I replaced my ac compressor. The hardest thing for me was making sure the water pump gaskets stayed in place while I was installing. Watched a few YouTube videos and saw a guy use rubber bands to keep the gaskets in place. Worked like a charm!
I’ve heard of that being an issue with the gaskets. Couldn’t you use a bit of Permatex to help keep them in place instead of rubber bands?
I replaced mine last year without getting underneath it (this was before I had a floor jack and jack stands)- I was able to drain the coolant by removing the hoses from the water pump with a catch pan underneath. I found the easiest way to get the serpentine belt off was removing it from the water pump bell and when replacing, putting the belt around the water pump bell last. Have a serpentine routing diagram handy.
I found some of the hoses a bit difficult to remove, I used a dental style tool (pick) to get underneath the hose and ran it around the circumference and that proved to be a huge help in getting the hoses off. There is actually a specific tool for this (hose removal hook), but the dental tool worked just fine for me in order to break the adhesion.
I encountered no issues with the old gaskets (thankfully). Getting the new gaskets in place was the most challenging part of the job for me- I used the rubber band trick- and it worked like a charm. Also you should put in a new thermostat while you are at it. Be advised there are two styles of thermostats for our cars; I bought the wrong one and ended up having to run to an auto parts store to get the correct one.
Great - good to know! Admittedly I’m a little concerned about using the plastic valve on the radiator. At 20 years old I’d think it may break fairly easily. Using a hose makes perfect sense.
Good idea, that original plastic radiator drain valve is a real pain but cheap to replace. With a needle nose plier twist counter clockwise a quarter turn and pull about 1/3" or until draining commences. Draining from a loosened radiator hose may get antifreeze all over the garage floor if the container is misjudged..I misjudged the last change. If you are planning to replace the hoses anyway (great idea if original or older replacements), just make a small slice with a something sharp, in the bottom of the lower hose close to the drain with the pan directly under it. Not as messy. Replacing the water-pump yourself is very satisfying and a great learning experience!
Right when you start the job, before you do anything, buy a bottle of Permatex Indian Head gasket shellac. Take the pump out, apply brown magical goop, sit gaskets in place.
While you're removing the old one and draining the coolant, they will stick. Then you can literally just pop it in.
Not a bad job, but not very fun leaning over the car from the awkward side angles due to the hood. And the driver's side would be infinitely easier if the PS reservoir weren't in the way.... but yeah this is definitely a DIY level project.
I used a couple water pump bolts with the head cut off as a stud to install a new water pump. Cut a slot in each one in the end to use a screw driver to remove. Just another idea
The hardest part is keeping the new gaskets in place.
Got it done. And yes - keeping the gaskets in place while installing was the toughest part. Took me a bit but overall it wasn’t really that bad.
I tried to be careful taking the radiator drain plug out but it just kept spinning. The pin was sheared off so I had to pull it out. Replaced with a Dorman one (with the winged tab) and all good.
So far no runs, no drips, no errors. Saved myself the $250-ish that the local dealer quoted me for the labor.
