Gauge Bezzels
Old Jan 5, 2003 | 11:26 AM
The Yav's Avatar
The Yav
Default Gauge Bezzels
Has anyone installed chrome gauge bezzels without removing the instrument panel? If removed I understand if the instrument panel is left in the upward position for more than 15 minutes it could be damaged. :chevy
Old Jan 5, 2003 | 12:55 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Gauge Bezzels (The Yav)
can't be done!
the cluster must come out. :cheers:
Old Jan 5, 2003 | 02:17 PM
UtahVince's Avatar
UtahVince
Damage could result if the IP is not left in an upright position.
Old Jan 5, 2003 | 03:17 PM
geck's Avatar
geck
Default Re: Gauge Bezzels (RPOZ4Z)
can't be done!
:iagree:
If the cluster didn't have to come out everybody would have them. :D
Old Jan 5, 2003 | 03:49 PM
qs_zo6's Avatar
qs_zo6
Default Re: Gauge Bezzels (UtahVince)
what find of damage?
Old Jan 5, 2003 | 04:50 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Gauge Bezzels (qs_zo6)
If that is your only concern, it shouldn't stop you from doing the mod. The cluster sits just as it does in your dash for most of the install. It will sit that way by itself while you have it out of your dash on your work surface. The only time that you'll need to tilt it back momentarily is when you glue each bezel to the cluster. That takes less than a minute, so there really is no worry.
Go for it!
Old Jan 5, 2003 | 11:45 PM
SteveL2's Avatar
SteveL2
Default Re: Gauge Bezzels (C5 StockSwap)
In addition to what C5 StockSwap accurately states, I have yet to see any confirmation that there will be damage to the gauges if laid horizontally. A long time ago there was a thread debating this and no one had any official comments. Indeed, it also was pointed out that these things are shipped all the time, and there's probably no chance that they are always oriented upright during shipping. In any event, for the install it's easy to keep them uprights most of the time. :seeya
To Gauge Bezzels
