PORTING LS1 HEADS???
Old Jan 5, 2003 | 12:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default PORTING LS1 HEADS???
Has anyone on the forum ported their own heads? If so how difficult was it and did it produce the results that you expected.
Does anybody have any digital pictures of a ported intake port and exhaust port as compared to stock that they could post?
Are there any areas in a stock intake manifold that would benifit from a little bit of plastic removal?
Im thinking about trying to improve my stock 98 heads by doing some porting.
Bill
Old Jan 5, 2003 | 12:53 PM
vstella's Avatar
vstella
Default Re: PORTING LS1 HEADS??? (Bill Curlee)
I also had the idea to port my heads but after speaking with Wade Stevens from Agostino Racing Engines I let the professionals do what they do best..Perhaps this video will give you some insight to what's necessary to port the heads..
GO TO MY video library and right click ARE Heads..
http://www.badazcorvettes.com/~vstella/video/
[Modified by vstella, 1:21 PM 1/5/2003]
Old Jan 5, 2003 | 01:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: PORTING LS1 HEADS??? (vstella)
VSTELLA
The link that you referenced did not function. Could you please check it
Thanks BILL
Old Jan 5, 2003 | 01:10 PM
vstella's Avatar
vstella
Try it now ..:D
Old Jan 5, 2003 | 02:31 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Unless you have experience, I would not try to port your own heads. All you will end up is with a large paperweight :)
Old Jan 5, 2003 | 05:22 PM
David Plum's Avatar
David Plum
Bill ther is a good article by Mondello in an engine builders magazine I will try to find it copy and send to you . I did my own heads Ive been porting cylinder heads using flow benches for 10 years . Dont be afraid to do your own every one is stuck on cnc heads thats nice if you have $1500 dollars to spend . If you just blend the bowls remove rocker arm stand area into port that will leave holes use sealer on bolts or epoxy holes raise exhaust tear drop both valve guides that is huge alone . And search for an article by Pat Musi in one of the street car shoot out magazines he goes into modifying the ls1 head Also ck out some of the companies web sites good upclose pictures . Any ques. email me hplum@erols.com DONT GET CAUGHT UP IN THE HYPE
Old Jan 7, 2003 | 11:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: PORTING LS1 HEADS??? (David Plum)
Dave
Someone on the LS1 site stated that there was going to be a manual released sometime in April about performance mods for the LS1 & LS6. Ill be first in line to get it. They said it contains detailed instructions on porting LS1 Heads. :thumbs:
I will get the name of the manual and the publisher and post it here later.
Bill
[Modified by Bill Curlee, 10:10 PM 1/7/2003]
Old Jan 8, 2003 | 12:16 AM
boost2much's Avatar
boost2much
HMMM......I think I might have found another DIY project :-D Please post that book when you get the info.
Old Jan 8, 2003 | 08:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: PORTING LS1 HEADS??? (boost2much)
BOOST@MUCH
Nooooooooooo Problem! :thumbs: I'm going searching for it soon.. I'll be grinding and port matching right along with ya!!!!!!!!!!!!!!! :cool: :cool: :cool: :cheers:
Bill C
Old Jan 9, 2003 | 12:47 AM
houseofspeed's Avatar
houseofspeed
While I can appreciate the DIY spirit...head porting is not a DIY project if you are truly looking for results. I have been in the race engine game for 15 years and still don't know all there is to know about porting, and every time a new style of head hits production..its back to the drawing board.
I can tell you that the product of your labor in your garage with a Dremel tool is no where near what I can supply you with. I have spent the money to get the combo right (in terms of seats, port shaping, etc.) so why experiment. Buy the best and move on to your next mod.
Old Jan 9, 2003 | 10:05 AM
Kenny94945's Avatar
Kenny94945
Hello Bill and all,
Thanks for opening this topic.
House of Speed is more than likely right.
If I may, for a DIY, what do we all think about matching the intake ports to the gasket? Having not seen how the intake maniold matches the head, can we take away some plastic and aluminum and not get into trouble...assuming due care?
Can this matching be done with sandpaper or is the head aluminum to strong and will need a dremil (sp) tool? What about the composit plastic density?
Anyway, I would like to DIY a sandpaper port and polish to the intake side because I do not think I will get in trouble here.
The exhaust side...I do not know...I have headers and the header gaskets do not cleanly match the heads exhaust port.
Comments please.
Old Jan 9, 2003 | 07:59 PM
David Plum's Avatar
David Plum
Bill I found the article go to http://www.engine-builder.com look at dec 2001 article can you make your vette faster I think was title ck it out.
Old Jan 9, 2003 | 09:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dave
I found it.., Its called "Can a Corvette perform even better? You bet it can!, Joe Mondello, Engine Builder, December 2001" at this web site,, http://www.engine-builder.com/ Thanks
Bill
Old Jan 9, 2003 | 09:43 PM
Sam Lin's Avatar
Sam Lin
Default Re: PORTING LS1 HEADS??? (houseofspeed)
I think it depends on the results you're shooting for. If it's to make every last horsepower, then I definitely agree there's no way our DIY porting will hold a candle to yours or any other tuner's heads.
However, if the results we're wanting is to simply gain some power for cheaper than the $1500 a set of CNC'd heads cost, then to spend $50 on some tools and some hours of our own free time is even better bang for the buck than a "performance" intake. Unless we go past the popular porting areas and dumbly try to really hog out a lot of material, chances are very slim that we'll hurt anything or LOSE power.
Sam
BTW, direct link to the article is here: http://www.babcox.com/editorial/ar/eb120118.htm
[Modified by Sam Lin, 7:46 PM 1/9/2003]
Old Jan 9, 2003 | 09:54 PM
Mordenkanen's Avatar
Mordenkanen
:D :chevy :thumbs:
Old Jan 9, 2003 | 10:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: PORTING LS1 HEADS??? (Mordenkanen)
Sam
Man,,, your singing the same tune that I was thinking.. All I want to do is some blending and some minor reshaping. I will increase my flow and performance and save bucks for other things.
I have 4 vetts to keep going and droping $1500-2000 on a set of heads is out of the game plan. I'm not out to set land speed records. All that I want to do is improve what I already have.
Bill C :cheers:
[Modified by Bill Curlee, 9:42 PM 1/9/2003]
Old Jan 10, 2003 | 12:24 AM
houseofspeed
Default Re: PORTING LS1 HEADS??? (Sam Lin)
Sam...I appreciate your comments, but you would be surprised what "eyeball" porting will do to the performance of the head. Not saying that everyone can afford a "tuner" set of heads...but likewise, don't hurt your cause by assuming that the DIY'er can't hurt his/her potential with several swift strokes of the grinder.
Good luck to all.
Old Jan 21, 2003 | 12:46 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hello all:
Well I found a few books that may shed some light on how to port your own LS1 or LS6 heads.
They are: How to Build & Modify Chevrolet Small-Block V-8 Cylinder Heads (Powerpro Series) and Chevy Ls1/Ls6 Performance by Chris Endres. $13.27
Both of these books can be found on Amazon.com. I already have them on order!!!
Bill Curlee
:thumbs:
To PORTING LS1 HEADS???
