Column Lock Bypass Update!
Old Jan 5, 2003 | 03:46 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Column Lock Bypass Update!
Just finished installing the bypass and it worked like a champ!!!
I did get the message after initital start-up, but I pulled #25 and #29 fuses, the re-installed and she started right up, no codes :D
Lemme thank Paul of COH for getting me the part overnited, really appreciate that :D :cheers:
To everyone who had advice on getting it unlocked, thanks...seriously appreciate all the input, I feel like an expert now :)
Lastly, to all those who think, "it can't/won't happen to me" please take my example and the countless others as an opportunity to not have it happen to you :) :cheers:
Old Jan 5, 2003 | 05:02 PM
C6~Missle's Avatar
C6~Missle
Default Re: Column Lock Bypass Update! (Mean Green 2000)
Good job... I got the bypass installed before it had a chance to give me trouble. Its been over 3 years with no CL and no problems.
I still can't believe GM could create such a lousy designed part and continue to use it on new models...
mike
:confused:
Old Jan 6, 2003 | 12:15 AM
mozin's Avatar
mozin
Default Re: Column Lock Bypass Update! (C5~Missle)
Yep, I am looking at the Infiniti G35 coupe instead of the C6. My 1996 Maxima SE has never had a problem of any kind whatsoever and it drives great.
Old Jan 6, 2003 | 08:03 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Column Lock Bypass Update! (mozin)
I wouldn't go that far :eek:....I believe with the 01s and newer it isn't an issue :cheers:
Old Jan 6, 2003 | 08:51 AM
C6~Missle's Avatar
C6~Missle
Woah! :confused: I consider the CL problem to be a minor annoyance. It can easily be bypassed, problem solved. GM should have resolved the problem long ago.. that is annoying. :mad
The C5 is very reliable and the fun factor is thru the roof! :thumbs:
I would never consider giving up on the vette. The vette is world class in all the areas that matter.
Would never consider the nissan as a replacement for the vette!
No other sports car offers comes close in performance and value at its price range... besides.. its a vette! :cheers:
mike
Old Jan 6, 2003 | 01:01 PM
WildKarrde's Avatar
WildKarrde
From: My tolerance for stupidity is at an all time low.
Only if you have an automatic.
Old Jan 6, 2003 | 04:48 PM
exracer28's Avatar
exracer28
Default Re: Column Lock Bypass Update! (WildKarrde)
My 01 Z06 just got out of the shop, 2 weeks, to get the column lock repaired. I would have to saay that it is NOT fixed on 01s.
John :confused:
Old Jan 6, 2003 | 05:30 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Column Lock Bypass Update! (T1Z06)
John :confused:
didn't know that, sorry....guess it's only the A4s :(
Old Jan 6, 2003 | 05:47 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Right! As far as I know, the 6 speed cars all way through 03 Vettes are STILL apt to lock up. :nonod:
TomW
Old Jan 7, 2003 | 07:55 AM
Richy's Avatar
Richy
Default Re: Column Lock Bypass Update! (TCW)
I had the bypass on my '99FRC.Who now makes one for the '02 and later
6 speeds?
Old Jan 7, 2003 | 08:01 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Column Lock Bypass Update! (Richy)
6 speeds?
COH :cheers:
Old Jan 7, 2003 | 11:13 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
6 speeds?
COH :cheers:
It is the same part number for all years. :cheers:
Old Jan 7, 2003 | 01:34 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Column Lock Bypass Update! (racer44)
Glad to hear your back on the road Mark and at least things weren't too bad.
Old Jan 16, 2003 | 08:44 AM
Thunder7's Avatar
Thunder7
Out of curiosity, what message was displaed that required you to do this? I'm researching CLB.....
Old Jan 16, 2003 | 08:50 AM
PowerMad's Avatar
PowerMad
Warning Will Robinson! Danger! Danger! Infiniti already issued major recall of some 35,000 G35's. In addition, dealer services have changed to policies that nickel and dime you to death. In addition to my 6, I have both a Lexus and an Infiniti... from my experience with the two, Lexus wins hands down. However, nothing matches the joy of my 6.
dave
2001 Z06 Speedway White/Firethorn Red
Old Jan 16, 2003 | 09:00 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In IV Veteran
Default Re: Column Lock Bypass Update! (PowerMad)
:thumbs: You're turning into quite the mechanic Mark! :hurray:
Old Jan 16, 2003 | 11:21 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Column Lock Bypass Update! (Mag Red Monster)
I just bought a 00 where or how would I check for the bypass?
Thanks,
Old Jan 16, 2003 | 12:34 PM
kenrobb's Avatar
kenrobb
Default Re: Column Lock Bypass Update! (93Polo)
With the ignition off, see if you can turn the steering wheel back and forth. If the wheel turns you have a bypass installed. Or GM recall work done on an Auto. If the wheel is locked, you don't. Bypass module is usually mounted up under hte lower dash panel. Hard to look for w/o removing panel. Good pictures on an installation http://www.97vette.com
[Modified by kenrobb, 11:36 AM 1/16/2003]
To Column Lock Bypass Update!
