Rev Limiter
Old Jan 5, 2003 | 07:34 PM
CP's Avatar
CP
Default Rev Limiter
Is the rev limiter done by fuel cut off or by coil pack cut off? I think the coil pack cut off would be quicker than fuel cut off. My vote is for coil pack cut off.
Old Jan 5, 2003 | 07:37 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Rev Limiter (CP)
Fuel cutoff, that's why it can be so damanging on nitrous.
[Modified by Godspeed, 6:38 PM 1/5/2003]
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
I think it is fuel cutoff at 6250!
Old Jan 5, 2003 | 07:43 PM
Shag Finger's Avatar
Shag Finger
Default Re: Rev Limiter (NEED FOR SPEED)
My Z went all the way to 6700 :steering:
Old Jan 5, 2003 | 07:44 PM
SAXN8R's Avatar
SAXN8R
Default Re: Rev Limiter (Godspeed)
I knew it was fuel cutoff, but explain how it can be damaging on nitrous? If there is no fuel to burn or detonate, then how can there be a problem. I am sure you know more than I do on this subject, but I just want to learn more.
[Modified by SAXN8R, 6:44 PM 1/5/2003]
Old Jan 5, 2003 | 07:48 PM
CP's Avatar
CP
Default Re: Rev Limiter (SAXN8R)
I was told it was coil pack shutdown last night because the fuel cutoff would be too slow. After all, the fuel runs at 40-50psi and would take a relatively long time to bleed down. Plus, electrical shutdown of the coil packs would be much quicker from the PCM.
Old Jan 5, 2003 | 07:57 PM
kwik8racr's Avatar
kwik8racr
Because even when the fuel is shut off, if you dont have a window switch for the nitrous, it will still be spraying nitrous in the motor with no fuel.
Thats why a window switch is important, you can set it to shut off your nitrous before you hit the rev-limiter.
A lot of guys do damage by not shutting off the traction control too. If you spray it with T/C on, it spins the tires so fast that T/C kicks in, shuts off the fuel, but you are still spraying nitrous into the motor. Not a good combo!
:nono:
Old Jan 5, 2003 | 08:15 PM
SAXN8R's Avatar
SAXN8R
Default Re: Rev Limiter (kwik8racr)
Okay,
Thanks for the explaination, but I am still confused. Does nitrous burn on it's own? I thought that nitrous wasn't flamable by itself. I must be stupid or somthing, because I don't understand if there is no fuel for combustion, how can you have detonation? Thanks again for trying to make the explaination idiot proof!
CP, the fuel is cutoff at the injectors. There is still fuel preassure, but the injectors stop spraying fuel, so there is no fuel going to the cylinders immediatly at fuel cut-off. This instantly will shut down the engine.
Old Jan 5, 2003 | 08:22 PM
CP's Avatar
CP
OK. Got it. It's not shutting down the fuel pump. I thought they just interrupted the signal to the coil packs.
Old Jan 5, 2003 | 08:48 PM
SAXN8R's Avatar
SAXN8R
I don't think that would work too good, because then there would be unburnt fuel poored into the cylinders and once the engine got below the rev-limiter....Booom! :eek:
Old Jan 5, 2003 | 09:13 PM
newberd's Avatar
newberd
Maybe it just closes the TB a little. That's how an eletronic WOT switch knows to stop spraying. :cheers:
Old Jan 6, 2003 | 04:22 PM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default Re: Rev Limiter (newberd)
I learn something new here everyday.
:cheers:
Old Jan 6, 2003 | 06:02 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Right on! The ECM simply quits firing the injectors. Also, the command to quit firing the injectors happens about 6020 (LS1) rpms but the tach will be at 5800 rpms cause the tach lags the actual rpm.
Tom
Old Jan 7, 2003 | 12:31 AM
scool93535's Avatar
scool93535
Default Re: Rev Limiter (TCW)
Tom
TCW - Is that a typo, did you mean 6200?
:cheers:
Old Jan 7, 2003 | 01:32 PM
C5Longhorn's Avatar
C5Longhorn
Okay,
Corey,
Here's my stab at it. Other members feel free to correct me. N20 release 2 oxygen atoms, so even without fuel under the pressure and heat, the 02 atoms are still going to burn. Also, wouldn't the spark plug still be firing?
Old Jan 7, 2003 | 01:43 PM
J-Rod's Avatar
J-Rod
Default Re: Rev Limiter (rschiltz)
The air we breathe is about 12% oxygen. Nitrous is 2 parts Nitrogen which makes up 80% of our atmosphere, and 1 part oxygen. Hence you get 33% oxygen vs 12% in the same ammount of space (your cylinder). Well, all that oxygen needs fuel to combine with. No fuel mean you go lean...
If you run a motor lean what you get is a rapid rise in chamber heat. All that oxygen acts just like the oxygen enrichment on a blowtorch it simply blows a hole through the piston just like a torch...
One thing, lean engines make more power. In racing lean is mean... But lean is also dangerous. You have to be on top of your game or dead holes is the result....
To Rev Limiter
