Dim Climate Control unit, no A/C
Old Aug 8, 2022 | 03:19 PM
ColeLS6's Avatar
ColeLS6
Default Dim Climate Control unit, no A/C
Just got another C5Z, no A/C. Could a dim climate control unit (from bad solder) that has dimmed to the point it's now just a blank screen, cause the AC compress to no come on? The fan control does work. I'm about to pull it apart to re-solder this weekend but wondering if I have another issue. AC has charge.
Edit: found out the issue DTC code b0361, I'm stuck with the heater on and need a new actuator.
Old Aug 9, 2022 | 03:43 PM
huesmann's Avatar
huesmann
No, you probably have the bad connections on the chips. The solder needs to be reflowed.
I doubt that problem would affect the compressor.
Old Aug 9, 2022 | 04:14 PM
ColeLS6's Avatar
ColeLS6
Thanks it appears I'm pulling my center console and radio/hvac controls and re-soldering, then pulling the gauges to access the drivers side actuator and replace it.
Old Aug 9, 2022 | 04:51 PM
Smoken1's Avatar
Smoken1
Do both actuators while your in there. The other one is just as old and ready to take a crap as soon as you put it all back together
Old Aug 10, 2022 | 08:04 AM
ColeLS6's Avatar
ColeLS6
Good idea, got 2 on order!
Old Sep 6, 2022 | 04:43 PM
ColeLS6's Avatar
ColeLS6
Both actuators now replaced and re-soldered HVAC control, bright screen and cold air!
To Dim Climate Control unit, no A/C
