Vibration fix Inside RearView Mirror DD8 Auto Dim
Old Aug 9, 2022 | 01:14 AM
gtzy's Avatar
gtzy
Default Vibration fix Inside RearView Mirror DD8 Auto Dim
My mirror vibrates causing a blurry view of objects in the mirror. Discovered the clip that slips over the metal tab glued to the windshield is loose. It is attached by two tabs. Used a very small punch to peen the outer edge of each tab to remove the slop.I used a GM mirror removal tool to release the metal spring clip.
Lisle 60400 Mirror Removal Wrench
Easily Removes Mirrors Held on By Spring Clip Without Damage to the Windshield or Mirror.
Simply insert the tip of the tool under the mirror where it attaches to the windshield. Push the tool towards the glass and down to release mirror from bracket. Coating on bend
helps protect windshield.
