Removing auto-dimming mirror...
I can see the clip that holds the mirror to the mount when I look in from outside the windshield, and everyone seems to say you have to put a prying device in there to move the clip to release the mirror (everyone agrees the GM instructions to rock the mirror back and forth while pushing upwards doesn't work and often breaks the windshield). My question is, does the clip need to be pushed towards the windshield or pried away from it?
That is, do I need to:
a. get my prying tool between the clip and the glass and push it away from the glass? Or do I need to
b. get the prying tool between the clip and the mirror mount housing and push it towards the windshield?
I'd really like to not break the windshield in the process of getting the darn thing off. I have a replacement mirror on the way, and hopefully looking at the mounting on it will help answer my question, but guessing someone here has figured this out. All the electronics in the mirror seem to be shot with the exception of the little amber light that illuminates the gear shifter area- I tested the harness and it is sending power to the mirror- it's just dead. It never dims at night when headlights are behind me no matter how many times I press the "O/I" button, and the map lights won't illuminate even though I've tested both of the six-bulb sets and they're both good.
Thanks for any advice!
May i ask what does the auto dimming mirror do or alternate functions from the normal regular lighted switch mirrors? Does it run off the drl defrost dash light sensor? Or interior light sensor on the DIC button cluster.
Main thing im asking is how to remove the mirrors as well?
Here is a picture of the clip taken through the windshield. From the other threads on this topic, I'm assuming that clip needs to be wedged either up or down to get the mirror to release from the windshield (however, I've tried pushing in both directions with a plastic trim removal tool without success). Some of the threads also have a picture of a GM tool specifically made to remove the mirror (basically just a bar with a bend at the end), so I'm thinking I might need a metal pry tool.
At this point, I'm just asking which direction I need to push the clip in- towards the windshield or away from it.
If you Google "GM rear view removal tool," the results will pull up a bunch of different tools that all look pretty much the same.
The instructions that accompany the description of each of these tools is pretty consistent as well.
Place the end between the mirror housing and the clip and push upwards towards the glass.
I'll eventually follow up with either a picture of a successfully removed mirror (or a broken windshield)...
