Unhappy with 4.10 gears!
Old Jan 7, 2003 | 01:56 AM
enloe's Avatar
enloe
Default Re: Unhappy with 4.10 gears! (CJS)
Can someone here help me out? What would be top speed in 4th gear with all the gear options (3.42, 3.73, and 4.10)? I ran at the track once and I trapped at 111.11 MPH and I had just shifted into fourth gear with the stock 3.42 gears. I would like to know approximately what RPM I was at and what I would have theoretically been at with different gears.
Old Jan 7, 2003 | 02:33 AM
C5_PIG's Avatar
C5_PIG
Default Re: Unhappy with 4.10 gears! (enloe)
Love my 4.10's
Old Jan 7, 2003 | 04:45 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
For an MN6 at 6200 in 4th: 3.42-142.7; 3.73-130.9; 3.90-125.2; 4.10-119.1
That sounds about right for just shifting out of 3rd and into 4th at 111mph. At 6200 rpms, 3rd will run out at 109.7 mph.
[Modified by FunDriver, 1:57 AM 1/7/2003]
Old Jan 7, 2003 | 09:52 AM
RED99HT's Avatar
RED99HT
Default Re: Unhappy with 4.10 gears! (FunDriver)
You also have to take into consideration what size tire you are going to run on the street and track. If you use a 17" drag radial at the track then it would lower your gears. A 3.90 gear would become a 4.05 with a 17"tire. 4.10's would then effectively become a 4.26. Check your tire sizes and what you plan on using in future to help you make a decision.
