Brake Light Wires
Old Jan 6, 2003 | 04:29 PM
allanlaw's Avatar
allanlaw
Default Brake Light Wires
Is there any place inside the rear hatch to tap into the brake light wires? I know where to find them on the outside (under the license plate, etc.), but do they run somewhere under the carpeting so I can pull the signal for a data logger that may be installed in one of the storage wells?
Old Jan 6, 2003 | 10:16 PM
davidfarmer's Avatar
davidfarmer
Default Re: Brake Light Wires (allanlaw)
I think it runs under the floor, down the torque tube and into the right rear fender. You should be able to pull one of the rear lights, tap into it, then drill from there into the rear of the cargo hold.
Dave
Old Jan 7, 2003 | 02:13 AM
allanlaw's Avatar
allanlaw
Default Re: Brake Light Wires (davidfarmer)
Thanks, Dave. I wanted to avoid having to drill through, but that may be the only way to do it.
To Brake Light Wires
