What is wrong with my AC?
Old Aug 29, 2022 | 07:05 PM
Stephen Meredith's Avatar
Stephen Meredith
Default What is wrong with my AC?
Video in post. Just started yesterday. When my AC is on, ONLY when I turn left it makes this squealing kind of noise. It appears to be coming from the vents, but I'm not positive. If I turn the ac off mid-squeal, it stops immediately. But it only happens when AC is on & turning left. Wtf?
https://imgur.com/a/ud0z8iR
Old Aug 29, 2022 | 07:22 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
My quick guess is that your fan is the problem. When you turn left, the fan may shift or flex and the blades could be hitting the housing. I'd drop the kick panel on the passenger side and get a friend to either drive or listen and see if it your fan. Good news is that if your fan is FUBAR it is a super easy fix. You may get away with loosing the nuts and repositioning the fan.
Old Aug 29, 2022 | 08:14 PM
Stephen Meredith
Are you talking about the fan in the blower motor?
Old Aug 30, 2022 | 03:06 AM
gpracer1's Avatar
gpracer1
If that were the case just leave the fan on high and test. I’m guessing a belt.
Old Aug 30, 2022 | 08:48 AM
1999corvettels1's Avatar
1999corvettels1
Does it do it in driveway or in parking lot while just turning steering wheel left with ac on?
Old Sep 1, 2022 | 07:18 PM
Stephen Meredith
no. only when moving
To What is wrong with my AC?
