Front end suspension noise
Old Aug 30, 2022 | 06:56 PM
LstHura's Avatar
LstHura
Default Front end suspension noise
I need help diagnosing a problem. After I have driven by 2004 for 15 - 20 miles I can hear a noise coming from the front end. It is more of rattle than a squeak. The problem goes away as soon as the car cools off. If I get out of the car and push down on the left front fender, I can hear what I can best describe as a rubbing/squeaking noise. Pushing on the passenger side sometimes gives me a noise, but still sounds like it is coming from the driver's side. By the time I get the front of the car jacked up and the wheel removed, the noise quits. I bought it a few years ago with 48k miles, now I have 62k on it. It has not been raced nor is it a garage queen. My thinking is either the shock or one of the bushings. I don't see any signs of the shock leaking. Any thoughts or suggestions to help me find the culprit would be appreciated. I don't want to start just throwing parts and $$ at it in the hopes of maybe fixing the issue.
Old Aug 30, 2022 | 07:14 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Take a look at your tie rod ends. This is a known "noise maker" and with over 60k on the car you may need a set. These are pretty easy to change. Lots of options out there but is OEM is just fine.
Old Aug 31, 2022 | 09:56 AM
LstHura's Avatar
LstHura
Thanks, I'll do that.
Old Aug 31, 2022 | 10:40 AM
ZEEZERO-6's Avatar
ZEEZERO-6
also check the sway bar end links ...
Old Aug 31, 2022 | 04:50 PM
LstHura's Avatar
LstHura
I checked the sway bar and tie rod ends. There is no play in them. Took the car out for a ride to get it warmed up. Got back to the garage, pushed down on the fender and can hear the squeaking. Took the wheel off and set the car down on a block. When pushing the car down I can see the upper control moving, but the bushing isn't moving with it. I expected to see the bushing and control arm to move together and any movement would be around the dogbone that goes through the bushing. If my thinking is correct, the lubrication around the dogbone is gone and is forcing the bushing to move up and down inside the control arm.
Old Sep 1, 2022 | 09:40 AM
Moved to C5 Tech.
Old Sep 5, 2022 | 10:23 AM
DWC4's Avatar
DWC4
Default Silicone spray!
Fixes a lot of squeaks. maybe not permanently but for awhile at least. Cheap fix to try.
Old Sep 5, 2022 | 03:47 PM
LstHura's Avatar
LstHura
Yeah, I'll give that a try. Thanks.
Old Sep 20, 2022 | 11:08 AM
LstHura's Avatar
LstHura
Just to follow up on this. I sprayed silcone on the upper driver side bushings. This helped quiet the squeaking. I ordered new bushings and put those in a few days ago. Nice and quiet and I haven't noticed any difference in ride stiffness, but it's only been a few days and I haven't had the car on a very twisty road yet.
Also, want to say thanks to billschroeder5842, ZEEZERO-6 and DWC4 for their suggestions.
Old Sep 20, 2022 | 11:14 AM
smitty2919's Avatar
smitty2919
You ordered new front upper rubber control arm bushings? Where?
Old Sep 20, 2022 | 01:37 PM
LstHura's Avatar
LstHura
I went with Energy suspension and bought the front bushing set directly from them. If you are going to get these, I suggest ordering the small tub of grease extra. I found the three little tubes they include was barely enough for one side. I need to get more before doing the passenger side.
https://www.energysuspensionparts.com/3.3176
Old Sep 20, 2022 | 07:13 PM
eyekyu's Avatar
eyekyu
anyone one recommend upper and lower bushing kit?
Old Sep 21, 2022 | 12:41 AM
jim993's Avatar
jim993
I would first grease the sway (stabilizer) bar bushings. Disassemble and grease, don't just spray. Quieted my suspension for the last 12 years. Synthetic grease.
To Front end suspension noise
