Does GM recommend replacing the bolt when replacing rear shocks?
Old Sep 1, 2022 | 03:06 PM
DWC4's Avatar
DWC4
Default Does GM recommend replacing the bolt when replacing rear shocks?
I"m about to install my new Bilstein rear shocks at about 130K miles on my '03 C5 and I know in the last change at least (there were two previous shock changes not done by me), I did not replace that lower bolt or nut.
I just watched a YouTube (uh oh) on the process to refresh my memory and he quotes GM as saying, replace the bolt and nut every time you change out the shocks. But he skipped it himself.
I was all set to do this today and now, I'm going to hold off and see how difficult it is to even find that bolt and nut. I'm betting they're GM only parts, I tried GM Parts Direct. - no luck there.
(yes I'm doing new in front also)
Thoughts?
Old Sep 1, 2022 | 05:56 PM
C6_Racer_X's Avatar
C6_Racer_X
The bolt should be OK to reuse.
The nut is probably a prevailing torque type "lock nut" and should be discarded and replaced if it is that type. Those nuts are a "use once" type nut, and may loosen in operation if they are reused.
That's the engineering behind it. Lots of folks reuse the nut, and very few work loose. Murphy and Darwin are often busy with other more serious matters.
Old Sep 2, 2022 | 09:33 AM
DWC4's Avatar
DWC4
Well Murphy and Darwin seem to follow me around 'just waiting' so I'll at least try to get a replacement nut, or if not, a little loctite perhaps.
I will torque correctly.
THANK you both.
Old Sep 3, 2022 | 01:56 PM
Supercharged111's Avatar
Supercharged111
I've had my shocks out multiple times, never think twice about reusing the bolts and they don't magically work their way loose. I've done with the header bolts, head bolts on other cars, you name it.
Old Sep 4, 2022 | 09:03 AM
DWC4's Avatar
DWC4
That's kind of what I would think too, thanks. I'm willing to go the extra mile for new, just for that extra sense of 'doing it right' but, I think the old ones are going back in. I believe Lowe's however has what might be big enough and high enough grade bolts for the job if I do new ones. I might go see just for the heck of it.
THANKS
Old Sep 5, 2022 | 10:49 AM
badazzsi's Avatar
badazzsi
I have never replaced the bolt or nut on my 99 and I have coilovers now. My shocks had been out many times before the coilovers. you should be fine like others have said.
Old Sep 5, 2022 | 03:56 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I don't know what GM calls for but I do know track cars that have had the bolt in and out many times without problem. The torque spec on the bolt is quite high and I would look it up before final assembly.
Old Sep 7, 2022 | 02:47 PM
lionelhutz's Avatar
lionelhutz
Torque spec in some manuals is too high, like 156 lb-ft, and you will damage or even break the bolt at that torque. I believe something like 108 lb-ft is the correct torque.
Old Sep 8, 2022 | 09:23 AM
DWC4's Avatar
DWC4
Default 108 sounds right!
Thanks!
To Does GM recommend replacing the bolt when replacing rear shocks?
