Hood/bumper cover alignment
Old Sep 10, 2022 | 12:12 PM
walleyejack's Avatar
walleyejack
Default Hood/bumper cover alignment
Hood and front bumper cover alignment, most every C5 that I've seen that somebody's taken the front bumper cover off and put it on, it never lines up with the same level as the hood, including mine and I've put shims under I've tried everything to raise it up to align it with the hood and it's just in the middle right above the flags and I have no idea once you take these off I guess you're pretty much pooched to get it lined up again properly. And it doesn't seem to matter if it's a Stock hood or aftermarket because I've seen lots of stock hoods the same . If anybody's got any suggestions feel free.
Old Sep 15, 2022 | 08:59 AM
walleyejack
Am guessing no one has never had this issue have re and re bumper cover.
Old Sep 15, 2022 | 10:15 AM
workmanw's Avatar
workmanw
Signing on for response.
Old Sep 15, 2022 | 10:24 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
My bumper cover has been removed multiple times. It has even been totally replaced. Although I haven't always been happy with the panel gaps, It's always lined up fine with the hood. I had the work done by a reputable body shop. I have seen the issue that you are referring to on other cars. My advice would be to take it to a quality body shop, and have them correct the problem for you.
Old Sep 15, 2022 | 11:23 PM
Moved to C5 Tech for hopefully more suggestions.
Old Sep 27, 2022 | 09:33 AM
walleyejack
thanks. the gaps are ok, but it is a bit lower in the center of the hood, and can t see any way to shim it up
i used all the same screws and pins that came out. there was a small rubber bumper that fell out, no idea where it came from tho.
thanks
To Hood/bumper cover alignment
