C5 tune question
Old Sep 19, 2022 | 10:52 PM
Jack 2003's Avatar
Jack 2003
Default C5 tune question
I have 2 C5s both automatic. My original white 03 has never had a tune of any type, and is as stock as possible. My anniversary red on I bought with 22,000 miles. It seems to start quicker and has a louder exhaust. Could a tune create these differences? Both cars run great with no issues.. can a shop check to see if it has been changed..I know nothing about tuning on these cars. Your thoughts are welcomed…Jack
Old Sep 20, 2022 | 12:33 AM
jim993's Avatar
jim993
More likely that the slower starter has a slight fuel pressure leak down when sitting. Could be an injector or the check valve, or something else like a deteriorating crank position sensor or cam position sensor --but nothing I would worry about unless it gets suddenly worse.
To eliminate a slow leak down, put a pressure gauge on the fuel rail and monitor.
If the PCM programming is stock, a dealer can read it and confirm that it is stock
Old Sep 20, 2022 | 12:47 AM
romandian's Avatar
romandian
you can check this by priming the system (ign on) before starting.
Old Sep 20, 2022 | 09:22 AM
Jack 2003's Avatar
Jack 2003
The white 03 starts the same as when new. I just think the red 03 starts quicker and exhaust sounds better…both are stock…thanks for your ideas, Jack
Old Sep 22, 2022 | 06:00 PM
CinciZ06's Avatar
CinciZ06
A tune will not change the sound of your exhaust. However adjustment of some parameters in the tune can definitely cause a more crisp start. I would agree that more than likely you’re likely having fuel pressure leak down. Many of us live with it and it’s nothing to be concerned about immediately.
To C5 tune question
