remote entry
Old Sep 21, 2022 | 09:46 AM
sah1518's Avatar
sah1518
5th Gear
Default remote entry
I just bought my first vet, a C5, 1999. Both of my remotes are not working and they have new batteries in the remotes, any suggestions on the cause?
Old Sep 21, 2022 | 10:41 AM
jcgunn's Avatar
jcgunn
Try this:
Step 1
Insert the key into the ignition and turn it to the “Run” position. Turn off power to the radio.
Step 2
Press the “Reset” button on the driver information center to clear any warning lights. Press the “Options” button until a blank message appears on the DIC screen.
Step 3
Press and hold “Reset” on the 3 seconds. Press the "Options" button until "Fob Training" is displayed on the DIC screen.
Step 4
Push the “Reset” button. This will bring up the message “HOLD LK + UNLK 1ST FOB” on the DIC screen.
Step 5
Hold down “Lock” and “Unlock” on the remote at the same time for 13 seconds.
Step 6
Watch the DIC, as it will read “Fob Learned” when the programming is accepted for that remote. Repeat "Step 8" to program a second Fob, if desired.
If that does not work, open up the fobs and check for cold/broken solder joints on the PCB
Old Sep 21, 2022 | 02:09 PM
rrwirsi's Avatar
rrwirsi
The broken solder joints was my issue. You may need a magnifying glass to check.
Old Sep 21, 2022 | 02:42 PM
sah1518's Avatar
sah1518
5th Gear
Old Sep 22, 2022 | 05:09 PM
Endless Money Pits's Avatar
Endless Money Pits
This video I made shows the broken solder connection on my friend's C5 remote. I didn't repair it in this video but thought it might help you find the problem.
Old Sep 23, 2022 | 11:14 AM
sah1518's Avatar
sah1518
5th Gear
Thank you sir and I have ordered two new remotes...
To remote entry
