Recently on my 2000 C-5 the right-side window will not work, but if I open the door & squeeze or move the bundle of wires between the inner firewall & door will alleviate the problem for periods of time. Any one experience this problem?
My biggest concern was all my warning lights began flashing 2 times now.
1st time I contribute it to not waiting for the system to reset when you turn the key on. In other words, I started it like a regular car.
2nd time was trying to get right side window up while leaning across the console in order to open the door & push the up & down button. That did not work for the window but when I set back down in my seat normally all the warning lights had engaged.
If I turn the car off & wait maybe 2-3 minutes it does remedy the problem, so far.
Any thoughts about this?
MANY experience that here !!…there is connector inside that rubber boot…you’ll need to get in there and inspect the connector…you may have damaged, bent, or corroded terminals !!
