Parasitic draw
Old Sep 27, 2022 | 10:21 PM
Jpartida's Avatar
Jpartida
7th Gear
Default Parasitic draw
So I'm currently doing a parasitic draw test on my C5, I'm doing the regular pull negative cable removal method where I take out the negative cable and put the positive lead to the negative cable and the negative lead to the negative post and I see and amp draw of 1.35-1.29 but then all of a sudden it drops to .80~.70 and then finally down to .20 I never really expected this to happen, but does anyone have a clue on what happened? Could it be something specific as to why it dropped ? I'm completely clueless, I need help! Something that just happened recently is that my right headlight motor gear broke I'm not sure if maybe that could be the drain ?
*UPDATE*
so about 9 days later I finally found out what was causing the drain it turns out it was the horn, i unplugged the horn fuse relay and boom it stopped draining and the amps went down from 0.13 to 0.02, thanks to all the people that helped out!
Old Sep 28, 2022 | 02:05 AM
Endless Money Pits's Avatar
Endless Money Pits
That's what happens as the car falls asleep. 0.20 amps is still pretty high, I think .085 or less is normal but I'm not that great with electronics. If you meant 0.02 then you're car is fine.
Old Sep 28, 2022 | 03:24 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
.02 amps which is 20 milliamps is good after the cars modules “go to sleep” !!
Old Sep 28, 2022 | 07:45 AM
mmartinez's Avatar
mmartinez
What you saw was systems shutting down, until it entered sleep mode 20-25 ma is good.
Old Sep 28, 2022 | 03:25 PM
Jpartida's Avatar
Jpartida
7th Gear
Yeah my car is on .20 I think it might have a drain then
Old Sep 28, 2022 | 03:26 PM
Jpartida's Avatar
Jpartida
7th Gear
My car is actually on .20 amps😅
Old Sep 29, 2022 | 01:03 PM
mmartinez's Avatar
mmartinez
Yes that's way to high, suggest disconnecting your battery power cables at the engine fuse box, and the alternator output cable and then measuring sleep mode current. Connect the alternator output cable first, and check your current reading, then add either the engine bay fuse box or interior fuse box to determine which one has the excessive current drain.
Old Sep 29, 2022 | 03:38 PM
Jpartida's Avatar
Jpartida
7th Gear
I'll definitely have to give that a try, I fixed one drain issue which was something to do with my headlight motor, that dropped the amps down to 0.13
To Parasitic draw
