drivers door wont open
Old Oct 1, 2022 | 01:36 PM
justcable01's Avatar
justcable01
5th Gear
Default drivers door wont open
2005 base convertible I have replaced the touch pad, door latch and inside button. door still will not open. help?
Old Oct 1, 2022 | 02:34 PM
rrwirsi's Avatar
rrwirsi
You posted in the C5 area, 1997-2004. Suggest asking your question in the C6..
Old Oct 1, 2022 | 04:31 PM
mmartinez's Avatar
mmartinez
Regardless that your car is a C6, can you open the door from the inside? If you can open the door from inside the next step is to pull the door panel off.
Old Oct 1, 2022 | 04:46 PM
justcable01
5th Gear
it will only open by the emergency cables
Old Oct 1, 2022 | 05:42 PM
mmartinez's Avatar
mmartinez
That's good to hear, you have to remove the door panel to find out what's wrong.
Old Oct 1, 2022 | 05:45 PM
justcable01
5th Gear
like i said, everything has been replaced
Old Oct 1, 2022 | 09:35 PM
mmartinez's Avatar
mmartinez
Well sometimes you can just fire the parts cannon at a problem and sometimes you just have to do some troubleshooting. Sounds like the door is locked since you can't open the door with the door handles, there are two electrical connectors in the rubber boot between the door and car that over time can develop bad connections.
To drivers door wont open
