Blackwing installation problem?
Old Jan 8, 2003 | 01:38 AM
50-50's Avatar
50-50
Default Blackwing installation problem?
I just installed a new Blackwing along with a carbon fibre airduct on my '03. Coupe. As I'd hoped the result was favorable... noticeably more poop!
However, when I pulled back into the garage I noticed that the front edge of the hood is about 1/8" higher than the front end. I'm pretty sure it wasn't that way before.
I think the air duct is sitting too high & holding the hood up. There's almost 3/4" of clearance under the curve of the duct. It looks like I may have to shorten the front coupling hose between the MAF & Blackwing to bring the whole assembly forward & down a little.
Any other ideas or something I've overlooked ???
Thanks in advance. I've been helped out a couple of times here on the forum & I'm still trippin' over how helpful some of you guys are. I appreciate it. Hopefully I'll be able to answer someone's questions eventually... :smash:
Old Jan 8, 2003 | 01:56 AM
FNC80's Avatar
FNC80
St. Jude Donor '03-'04-'05
Default Re: Blackwing installation problem? (50-50)
Make sure the front grommets are seated properly?
Old Jan 8, 2003 | 09:23 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: Blackwing installation problem? (FNC80)
Sound advice. If the front wings of the filter aren't completely seated the filter will cause the exact problem you descibed.
Old Jan 8, 2003 | 11:30 AM
FYNL4's Avatar
FYNL4
:iagree:
Just put a BW on mine and had the same problem. I sprayed a little silicone spray on all the grommets (2 front of BW, and 2 at airbridge) and it seated easily and the problem went away. :thumbs
To Blackwing installation problem?
