Battery/Charging Issue
Old Oct 9, 2022 | 04:46 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default Battery/Charging Issue
I was out driving today (albeit on some bumpy roads), made a pit stop shutting off the car for about 15min, got back in the car and it was totally dead - no lights, no click, nothing. I had a battery pack, put it on the battery, and the car started right back up, no issues. Now, I am noticing that the battery voltage DIC is hopping all over the place ranging from about 13.5-14.2.
Now, the car is driving fine, made another stop for about an hour with the car off, got back in the car, started right back up, no DIC warnings/lights, battery voltage still fluctuating.
On my way home, I get ABS/Traction, Security, Reduced Engine Power, Shocks In-op. Get home, shut off the car, it starts right back up, and all the lights are gone, battery voltage still fluctuating.
Other Notes: I have not had this issue prior to today, battery is 1 year old, alternator may be original.
99 C5 with 96k miles
Any guidance is much appreciated, thank you!
Old Oct 9, 2022 | 06:02 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Test results from Advance Auto Parts just now. They said they couldn't test the starter, but everything else looks ok.
Old Oct 9, 2022 | 08:00 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Thanks for the test chart. My guess is that your voltage regulator getting wonky on you. Sometimes they go intermittently and sometimes they just....go. I think that yours is the former.
Old Oct 9, 2022 | 08:04 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Thanks for the reply. Is the regulator a separate part? Or is it part of the alternator?
Old Oct 9, 2022 | 08:55 PM
mmartinez's Avatar
mmartinez
Have you checked your battery terminals, making sure they are clean and tight. Throughout my year of corvette ownership I have experienced problems that were corrected by simply tightening the battery terminals.
Old Oct 10, 2022 | 12:31 AM
Smoken1's Avatar
Smoken1
For your 99 the regulator/brush assemblies part # is
https://www.ebay.com/itm/29235399634...0aAoKUEALw_wcB
Old Oct 10, 2022 | 12:36 AM
mmartinez's Avatar
mmartinez
I forgot to mention that you should check the cable connections at the starter solenoid, this is where the cable from the alternator connects to the battery. Many charging problems can be caused by dirty loose connections at the starter solenoid.
Old Oct 10, 2022 | 12:41 AM
jim993's Avatar
jim993
Voltage all over the place on the instrument cluster and symptoms like "ABS/Traction, Security, Reduced Engine Power," point to a failing ignition switch. Other symptoms of a failing ignition switch are that all symptoms disappear on restart but some or all come back on another later start.
A failing ignition switch is difficult to positively identify because of the (at first) intermittent and seemingly widely different symptoms. As the contacts in the switch become burned from arcing at contact, the conductivity to various systems becomes more and more intermittent.
And-- of course it could be something else.
My car is on its third ignition switch in 21 years and 118,000 miles.
Old Oct 10, 2022 | 09:47 AM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
The more I research, the more I think you might be on to something with the ignition switch...
Old Oct 10, 2022 | 10:01 AM
rrwirsi's Avatar
rrwirsi
Just a thought. Before replacing the ignition switch, try squirting some CRC Mass Air Flow Sensor Cleaner into the switch. Several years ago I had similar issues and did the 'squirt'. No further problems. I do the 'squirt' twice a year as part of my maintenance on the C5.
Old Oct 10, 2022 | 10:53 AM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
I can try that, I have some at home..
Old Oct 10, 2022 | 02:04 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Good info about tightening the battery cables, i had that issue in the past...
Old Oct 10, 2022 | 04:39 PM
Smoken1's Avatar
Smoken1
You could try this before buy a new one
https://www.corvetteforum.com/forums...ch-repair.html
Old Oct 10, 2022 | 04:44 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Thank you, looked through that earlier. Honestly, If I am going to go through the time to get to the switch, and the part is relatively inexpensive, I might as well just replace the part.
Old Oct 10, 2022 | 05:00 PM
mmartinez's Avatar
mmartinez
Before you go replacing the Ignition switch try measuring the voltage at the alternator output terminal and ground and then measuring at the positive battery terminal and ground they should be the same.
Old Oct 10, 2022 | 05:10 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Gave the battery terminals a crank, seemed fairly tight. Sprayed some MAF cleaner in the ignition. Car seems OK. I will continue to monitor and see if anyone else has suggestions.
Old Oct 10, 2022 | 05:39 PM
Smoken1's Avatar
Smoken1
All the new ones are made in China so good luck
To Battery/Charging Issue
Old Oct 13, 2022 | 12:50 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Car seems to be totally fine now with no explanation. Still have a new GM ignition switch on order to swap out as a precaution.
Old Oct 13, 2022 | 01:10 PM
jim993's Avatar
jim993
FSM says battery side terminal torque is 11 foot pounds. They need to be clean and tight. Could be the cause of the symptoms.
Old Oct 21, 2022 | 02:10 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
We are back on the road, turns out that the cables to the battery were bad, and had them replaced at my local dealer (Hawthore Chevy)...Happy Motoring!
