I. Just got a used bcm and had it flashed now I have a code shocks inoperable and I don’t not have ride control in this car I just bought a tech 2 scanner and when I get it I hope I can deactivate it any one else had this problem can’t go over 80 tried to clear it in the dash it clears it and it’s right back o. I believe because she shuts down at 80 every time thx jr
The flashing of the bcm has to be done with the vin number because it contains the options your car does or does not have, I am not knowledgeable about reprogramming a BCM but believe someone will chime in how to correct this.
Try following this procedure and see if it works.
1. Hook up Tech 2, turn car on, make sure module in the rear is plugged in. Do not unplug the rear module.
2. Use Tech 2 to delete the F45 option (F55 does not appear on the menu screen, use F45).
3. Save new configuration.
4. Do not turn car off, do not remove Tech 2. Go to the module in the rear of the car, unplug the grey connector (the widest one), leave any other plug(s) in. [leave the other 1 (F45) or 2 (F55) plugged in]
5. Turn off car, leave Tech 2 plugged in.
6. Remove remaining plugs from module in the rear of car. [never plug them back in again, if you do the F45 turns on automatically]
7. Turn car on to verify the "max speed 80 mph" is gone.
8. Unplug Tech 2.
You just have to skip the steps about unplugging the F45 module in the rear of the car that's where I would start
