‘97 C5 displayed; Engine at reduced power
Old Oct 12, 2022 | 01:49 AM
MyC5from1997's Avatar
MyC5from1997
6th Gear
Default ‘97 C5 displayed; Engine at reduced power
My c5 check engine light came on and first displayed in communication center, “engine at reduced power”
What to do next?
thanks
Old Oct 12, 2022 | 01:57 AM
darkside_ofthemoon's Avatar
darkside_ofthemoon
This happened to me once and left me stranded 2 hours from home. After much searching I found the engine harness rubbing and grounded out on a metal bracket at the back of the intake where the wiper cowling starts. I have to give a shout out to the forum for helping me find it.
Old Oct 12, 2022 | 09:11 AM
MyC5from1997
6th Gear
Default Thanks, how did you fix it?
thanks, how did you fix it?
Old Oct 12, 2022 | 09:24 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What to do next?
thanks
The FIRST thing you’d want to do is check for any codes…that may help in a diagnosis…your issue can be a handful of things…what fixed one car may not fix yours.
jackthelad's Avatar
jackthelad
One thing to try, is to disconnect the battery for a while (like 1/2 hour) and reconnect. Sometimes a fault can be spurious and this will clear it. Otherwise it's Tech II time to find what triggered the problem. I had it once due to a sensor failure. Dealer found and fixed it quickly.
Old Oct 13, 2022 | 06:27 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
My ignition switch was a culprit for the exact same message. The car would start rough, but the cluster gages and the AC would not turn on.
I ended up pulling all the fuses that said BCM on them in the passenger footwell. There are maybe four. Non were blown. One of the fuses made the BCM click and reset when I re- inserted it. All was well again.
I have a new ignition switch in the car now. I'll report if it occurs again.
I've had different issues with this switch if the key was not in it just right.
To ‘97 C5 displayed; Engine at reduced power
