When Installing Headers.......
Old Jan 9, 2003 | 12:41 AM
Rhynos99's Avatar
Rhynos99
Default When Installing Headers.......
If I install the off road pipes and install the O2 simulator sensors, where do they go. Looking at the directions it says install IN the header. Is this correct? :confused:
Old Jan 9, 2003 | 04:05 AM
jmX's Avatar
jmX
Default Re: When Installing Headers....... (Rhynos99)
o2 simms plug into the wiring connectors for the rear o2 sensors. They never install IN the headers. Most header setups don't even have holes for rear o2 sensors because they figure everybody is gonna use simms.
Old Jan 9, 2003 | 07:06 AM
Patches's Avatar
Patches
The connectors you need to access are next to the wall near the front O2 sensors. You detach the connectors and connect the O2 simms there and strap them out of the way of the collectors. :cheers:
Old Jan 9, 2003 | 08:06 PM
Rhynos99's Avatar
Rhynos99
Default Re: When Installing Headers....... (Patches)
Thanks for the heads up. :thumbs:
Old Jan 10, 2003 | 01:46 PM
kh24's Avatar
kh24
Make sure to plug the rear O2 holes also.
To When Installing Headers.......
