C5 corvette start engine question
Old Oct 30, 2022 | 04:35 PM
thevelvetglove's Avatar
thevelvetglove
Default C5 corvette start engine question
It seems that when start my engine it need to turn over much more than a few years ago. My corvette is a 2000 C 5 with 155,000 miles .
Old Oct 30, 2022 | 04:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Aloha !!…this may be due to a bad fuel feed check valve or a failing crank or cam sensor….to check if it may be the check valve turn the ignition on and off for 2 seconds (fuel pump will prime for 2 seconds) a few times and then see if the car starts right up…a crank or cam sensor is a little bit more difficult to diagnose…a fuel pressure gauge will be needed to diagnose the check valve.
Old Oct 31, 2022 | 03:58 AM
vette4fl's Avatar
vette4fl
Good luck. Aloha…mahalo….
To C5 corvette start engine question
