Blower Motor Relay Location
Old Nov 7, 2022 | 03:37 PM
GCD1962's Avatar
GCD1962
Default Blower Motor Relay Location
I've searched, but can't find where exactly the Blower Motor Relay is located. In the Pass side area near the BCM, or near the switch for the fan at the control panel ?
Old Nov 7, 2022 | 03:50 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
It looks like you have a 2000 (good idea to fill out your profile)…no relay as you can see in the picture…only a fuse, HVAC Control Module, Processor, and blower motor.
Old Nov 7, 2022 | 05:20 PM
GCD1962's Avatar
GCD1962
It is a 2000. Manual control. My diagram from the shop manuals show a Blower Motor Relay in addition to the Module. The relay is before the switch and power from #51 fuse
Old Nov 7, 2022 | 05:31 PM
C5 Diag's Avatar
C5 Diag
This are 2 schematics from my 01…one is FSM and the other is Mitchell…looks like the relay above the BCM…what’s your concern with this ??
Old Nov 7, 2022 | 05:42 PM
GCD1962's Avatar
GCD1962
The top diagram is what shows in my GM Manual, pg 1-160. The blower switch does nothing and there is no power to the blower control module. There is one relay above the BCM that was removed as per the instructions when I installed a LCM5 column lock by-pass. It did not say to re-install it. That is the only one I see above the BCM
Old Nov 7, 2022 | 05:52 PM
C5 Diag's Avatar
C5 Diag
Have no idea of why the relay would be removed for the LMC5 install ????…column lock not associated with blower motor.
Old Nov 7, 2022 | 06:51 PM
GCD1962's Avatar
GCD1962
I don't know if the one removed was for the col. lock motor, or for the blower motor. It was the only one I can see that is located above the BCM. I'll look again at the LCM5 instructions to see if had something to do with the power to the Col lock motor
Old Nov 7, 2022 | 06:59 PM
C5 Diag's Avatar
C5 Diag
Just refer to the wire colors of the relay if you’re not sure.
Old Nov 7, 2022 | 09:38 PM
GCD1962's Avatar
GCD1962
Will check tomorrow. Thanks
Old Nov 8, 2022 | 08:07 AM
DanA_F99_1977's Avatar
DanA_F99_1977
2024 C7 of the Year Finalist - Unmodified\
My car had two relays above the BCM. One is removed for the Column lock but the other stays. Not sure that helps but that is what my 2003 Z has.
Old Nov 8, 2022 | 10:04 AM
mmartinez's Avatar
mmartinez
There should only be two relays above the BCM, one is the column lock, the other is the TDR, sometimes referred to as the starter enable relay, it has four wires two smaller gauge yellow wires and two heavier gauge wires a red and violet.
Old Nov 8, 2022 | 06:49 PM
GCD1962's Avatar
GCD1962
Problem solved. I pulled the wrong relay. Didn't see the other 2 are they were crammed in above the BCM. Thanks for the help
To Blower Motor Relay Location
