Collasped hose
Old Jan 9, 2003 | 01:50 PM
mozart's Avatar
mozart
Default Collasped hose
Took the vette in today to the chevy stealer, oops I mean dealer cause the top radiator hose keeps collasping, sucking inward on cooldown. I had an earlier post and was advised it was probably a bad cap which I agree with, makes sence, but the stealer, I mean dealer ordered a new top hose. They had caps in stock but instead of putting a new rad cap on they insisted upon changing the top hose first. You can see and so can they that the coolant is not migrating back to the rad on cool down so it seems like a pressure relief problem with the cap. Oh well I guess I could be wrong but I will bet you they change the cap anyway. Probably more warranty $$ for hose change than for the cap. I know the cap listed foe $11.84, no labor to chance it. :rolleyes: I will post the results after this is done
Old Jan 9, 2003 | 08:24 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Collasped hose (mozart)
Mozart
I had the same problem with my 1998. Bought a 2002 radiator cap from GM. Oh my God...........there is a difference................same part number..........but there is a difference............hose doesn't collapse anymore. Problem gone
:steering:
Old Jan 9, 2003 | 09:32 PM
mozart's Avatar
mozart
Default Re: Collasped hose (vette#one)
Thanks for the info, I will insist they replace the cap also
Old Jan 10, 2003 | 01:42 PM
mozart's Avatar
mozart
Had the hose changed and insisted they replace the cap today. Works as advertized and the coolant is now returning to the radiator. I was told there was a change to the cap after 2001 to fix this problem. :)
Old Jan 10, 2003 | 01:49 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Any bleeding of the system needed when replacing the cap?
I know that an air bleed was required on the LT1 Firebirds.
Old Jan 10, 2003 | 02:28 PM
SFVetteman's Avatar
SFVetteman
Default Re: Collasped hose (Scissors)
Any air that is trapped in the radiator will be bled off to the surge tank :)
Old Jan 10, 2003 | 03:23 PM
Scissors's Avatar
Scissors
Default Re: Collasped hose (SFVetteman)
Thanks. :)
To Collasped hose
