I have had my headunit in my 2003 convertible swapped out with a double din Pioneer unit. My next goal is to change out the speakers with Kickers. I have talked with 2 different installers and one says that I can still use the Bose amp instead of getting different amp. The other says it will not be compatible. Who is correct?. If I have to replace the amp where have other convertible owners placed it where it doesn't overheat or tale up too much of my limited space. Also any recommendations for a smaller amp. Thanks...
I have all kicker in my coupe but the kicker amps are tiny the amp for the door and rear speakers fit behind the radio the 1000 watt for my subs fit under the glove box
How much bass do you want? Get a seperate amp for sure
