Knocking noise from torque tube?
Old Nov 24, 2022 | 06:26 PM
Ross68's Avatar
Ross68
3rd Gear
Default Knocking noise from torque tube?
I have a 2003 Corvette with the a4 that keeps messing up torque tube couplers. It makes a knocking noise at idle and I can't find any video anywhere online that sounds similar. when you lift the car up you can hear the noise from both the trans bellhousing and the engine bellhousing. It'll make the most noise when the trans temps go over 80 degrees. I had the torque tube rebuilt with new couplers and bearings about a year ago when it started making this noise the first time. when they took the assembly apart they found that the couplers were twisted and deformed(I didnt save a picture of one of the couplers). Versus everything I see online from other people who replaced their couplers they seem to just start cracking and falling apart from old age. So this along with the premature failure of the rebuild only lasting a year leads me to think something else is causing the failure. The car is completely stock. I've decided that I'm gonna just do the job myself and see what I can see when I take it apart myself and save myself some money but I would like to know if anyone else has had a similar problem and what you did to fix it. Thanks in advance.
Old Nov 25, 2022 | 11:49 AM
666lisa's Avatar
666lisa
https://youtube.com/shorts/FGHRl_fG_Ig?feature=share
auto in park TT does not move
Old Nov 25, 2022 | 11:58 AM
Ross68's Avatar
Ross68
3rd Gear
With converter and tranny in the back how would it stop the TT From spinning in park
Old Nov 25, 2022 | 12:16 PM
666lisa's Avatar
666lisa
When puttimng in park its pulling the gear of the main shaft that connects to TT. Theres clutche packs that engage to the main shaft
Old Nov 25, 2022 | 03:14 PM
Ross68's Avatar
Ross68
3rd Gear
But I can see both the converter and the shaft that connects to the flywheel spinning through the bellhousing inspection holes.
Old Nov 25, 2022 | 03:16 PM
666lisa's Avatar
666lisa
Yes but its not spinning in the trans. Its not connected intell u put it n gear
Old Dec 4, 2022 | 03:47 PM
coupe de vette's Avatar
coupe de vette
1st Gear
I believe I have the same exact issue, I noticed in park and neutral it makes almost like a random knock noise. When I’m gear it seams to go away
To Knocking noise from torque tube?
