Throwout Bearing vs. Normal Neutral Rattle Difference?
Old Dec 7, 2022 | 10:28 AM
DW600RR's Avatar
DW600RR
Default Throwout Bearing vs. Normal Neutral Rattle Difference?
Can someone explain the difference in noise or feel between a bad throwout bearing and the supposedly normal neutral rattle in M6 cars? I have an 02 vert that has the neutral rattle. When the car is cold, I get the rattle with the car in neutral and foot off the clutch. Push in the clutch pedal, noise stops. Once the car is fully warmed up, I don't hear the noise anymore. I just want to know what would be different if it was the throwout bearing.
Old Dec 8, 2022 | 09:50 AM
666lisa's Avatar
666lisa
There is no rattle with a stock clutch. When in neutral the whole drive train is turning push clutch in it stops. Something wrong. nJMO GET A VIDOE
Old Dec 8, 2022 | 10:38 AM
mmartinez's Avatar
mmartinez
There is a neutral rattle in stock m6 cars, if the throw out bearing is going bad you will hear it all the time.
Old Dec 8, 2022 | 11:50 AM
Supercharged111's Avatar
Supercharged111
Sounds like your torque tube bearings are shot.
To Throwout Bearing vs. Normal Neutral Rattle Difference?
