C5-R Block
Old Dec 8, 2022 | 11:57 AM
Rdubfalco's Avatar
Rdubfalco
Default C5-R Block
Okay CF,
I ended up getting a C5.R block from a deal that I worked out. I think this is more of a novelty these days since there are many options for the LS platform;
Dart, GM Bowtie LSX, LSR, RHS to name a few. I'm not sure this block is produced anymore and definitely didn't pay the $9K retail for it.
Anyways this is a 4 bolt head block and is priced higher than much better blocks from mentioned above.
Has billet steel caps, its been "hipped"​ and max bore/stroke is 4.160/4.100.
So I plan on having a 427" LS7 headed (Katech spec'd LS7 heads valves/guides, springs etc.) motor at 13:1 compression ratio. Hoping to get 705 flywheel (short travel lifters, sever duty rocker shaft, etc.).
Old Dec 8, 2022 | 01:12 PM
grinder11's Avatar
grinder11
Originally Posted by Rdubfalco
Okay CF,
https://www.youtube.com/watch?v=haaFtWlJ94g
Though the C5R block may not be capable of the larger displacements current aftermarket blocks are, I'd guess it's as strong, or stronger than, any other Aluminum block available. A 4.150×4.100 bore and stroke= a 444. That should snort down the track pretty good. It would also be a great candidate for FI, maybe with an LS9 blower. This would be capable of over 1,000, reliable hp. Unless you're shooting for a racing build, there's no way I'd be looking for 13:1 compression. To make 700+hp, you're looking at well over .650" lift. The LS7 heads aren't known for longevity with .600" lift! Dont ask me how I know!!! Just trying to offer suggestions. I have a 600+hp LS7 in my A4 C5, with about 11.25:1 compression. It's OK on pump gas premium, but only if coolant is under 200°F. I couldn't imagine going up almost 2 full points more. If I did, I'd have to run $10/gallon race gas. Best of luck to you......
Old Dec 8, 2022 | 01:19 PM
NW-99SS's Avatar
NW-99SS
2022 C2 of the Year Finalist - Modified
Match a set of C5R heads to it - and have Katech prep them since they are the expert on these motors since the C5R days which I see is already in your build plan
Old Dec 8, 2022 | 04:24 PM
Rdubfalco's Avatar
Rdubfalco
Not worried so much about drivability. I didn't mention that this will be a pump E-85 motor and I would upgrade cooling system and look into running an Aviaid 3 or 4 stage dry sump.
.650" plus lift of a cam doesn't scare me off. This is a toy, but I definitely will consider your experience and inputs. LS7 heads can be properly spec'd by Katech (geometry, CHE bronze guides, Exceldyne Ti intake valves, Ferrea hollow stem exhaust and their CNC port). Or can they?? Don't want to start the LS7 head debate!
What is your coolant system that you run?
What is you complete combination?
Does your coolant system struggle to stay under 200? 200-220 is normal on my stock LS6.
My only concern about LS9 and any other blower is cylinder pressure. I know there are Vulcan Cut-Ring head gaskets and 1/2" head studs etc.. I want to avoid lifting the head. This is just going to be a hi compression-hi RPM motor that were shooting for 750 and if we can get 800 on engine dyno were totally fine with that. No intent to go 4 digit power.
Old Dec 8, 2022 | 04:35 PM
Rdubfalco's Avatar
Rdubfalco
Good Point! I thought about C5R heads and they come pretty raw. The need to build those up would be more costly than the value for what I'm trying to accomplish 750 FWHP. Factory LS7 castings done right can make some steam! I feel like the C5.R heads are more of a novelty for what I'll be doing. I don't quite have C5.R money yet. Lol
Old Dec 8, 2022 | 04:43 PM
NW-99SS's Avatar
NW-99SS
I have a set of bare C5R heads, I'm just looking for a block deal like yours. And yes, the prep work will cost some additional cash no question. Hoping to top mine off with some ITBs. Looking forward to your build and results!
Old Dec 8, 2022 | 04:47 PM
Rdubfalco's Avatar
Rdubfalco
Niice!
Some rare hardware there. All you need is a block? The exact opposite of me lol Well these blocks are stupid expensive if you buy from retailer. Mine was aborted by 2 previous owners is how I got my hands on them. Still never used. I have to finish up my falcon first (also on YouTube channel) then I'll get after this one and plan on posting progress of this build to keep the community updated.
Do you have any pics of those heads you can share?
Old Dec 8, 2022 | 04:59 PM
NW-99SS's Avatar
NW-99SS
Niice!
Hoping for a deal like yours at some point! Here are the heads:
Old Dec 9, 2022 | 10:28 AM
grinder11's Avatar
grinder11
Interesting how the C5R heads dont use the cast in rocker arm pedestals! This is probably the way the production LS7 heads should've been made. You have to wonder how much this design change has to do with the LS7 heads issues! According to what I was told by a guy who tracked his C6 Z06, ITBs were worth an extra 50hp on the engine dyno, over a ported FAST 102 intake w/102mm TB. This was 8 years ago, and was on the same, modded engine, only change was changing the intake and 102mm TB to 8 ITBs. No air filter was available for the ITB setup then, so that may account for some of the power gain.....
Old Dec 9, 2022 | 10:34 AM
NW-99SS's Avatar
NW-99SS
According to what I was told by a guy who tracked his C6 Z06, ITBs were worth 50hp on the engine dyno, over a ported FAST 102 intake w/102mm TB. This was 8 years ago, and was on the same, modded engine, only change was changing the intake and 102mm TB to 8 ITBs. No air filter was available for the ITB setup then, so that may account for some of the power gain.....
ITBs generally use a simple mesh over the top, but my desire for ITBs is related to the car I'm putting it in, and how they resemble 4 Weber side draft carbs, but with a modern fuel injection setup. And 4 Webers are more money which is insane.
Old Dec 9, 2022 | 10:53 AM
grinder11's Avatar
grinder11
Right. But the mesh doesn't filter nearly as well as a proper air filter. If I was doing what you are, all track, I'd probably remove the screens. I've used them in velocity stacks thru the years, and they aren't a good filter, but still cost some amount of flow. Of course, the screens I'm talking about have a very fine brass screen, finer than a door screen......
Old Dec 9, 2022 | 11:02 AM
NW-99SS's Avatar
NW-99SS
Screens are mostly for static filtering - when sitting, or street cruising when power doesn't matter as much. Track day would be as you state
That said, the build is a long way off at the moment. Got to find a block first, raise my kids, and somehow find enough cash to pay Katech to put it all together...oh and a TR6060 if I can make it fit, if not, a Tremec M5 fits.
Old Dec 9, 2022 | 11:13 AM
Supercharged111's Avatar
Supercharged111
Who cares? ITBs sound amazing and their throttle response is second to none.
Old Dec 9, 2022 | 02:12 PM
Rdubfalco's Avatar
Rdubfalco
You're on the right track. Badass heads!! I'm sure there's a block for sale on here somewhere.
Have you posted a WTB thread in the C5 & C6 sections?
Old Dec 9, 2022 | 02:36 PM
NW-99SS's Avatar
NW-99SS
I will make a post when I'm ready. For now, will just buy one if I stumble on the right deal.
Old Dec 11, 2022 | 06:57 PM
Rdubfalco's Avatar
Rdubfalco
Right on makes sense, what's your price range on the right deal?
Old Dec 12, 2022 | 09:14 AM
NW-99SS's Avatar
NW-99SS
Great question - anything under 6K, would be something I take a serious look at.
To C5-R Block
Old Dec 14, 2022 | 02:31 PM
Rdubfalco's Avatar
Rdubfalco
Right on, they are an nice piece for sure. Hopefully someone here on CF has one for sale. Good Luck, would be cool to see that build come together.
Old Dec 14, 2022 | 03:34 PM
grinder11's Avatar
grinder11
Just a heads up on two things. One would be budget. If you have the coin, 800hp N/A can be done, but it's sure not cheap. Number two, and maybe more importantly, e85 can vary considerably in alcohol content! It's SUPPOSED to be 85% minimum. But LS7 heads are SUPPOSED to have a bullet proof valvetrain (according to GM!), too! For me, I'd be concerned about the 13:1 compression. If it was my car and engine, and it was going to be a track/street toy, I'd be leaning more towards VP racing fuel. I know it's pricey, but so are 800hp LS7 engines. My .02, and best of luck to you.....
Old Dec 14, 2022 | 03:39 PM
grinder11's Avatar
grinder11
They do sound cool, and have great throttle response. This is why all 2-3hp+/cubic inch, 12,000rpm+ motorcycle engines all use them. However, in a Corvette application, they also lighten the wallet a good $5,000.00, minimum!!! But, if the OP has the funds, by all means, he should go for it!!!
