Tpms
Old Dec 16, 2022 | 12:16 PM
JPoss's Avatar
JPoss
Default Tpms
Just had new new sensors put on and the tire place was unable to reset them and my local dealership doesn’t have a C5 TPMS reset tool. I bought a large magnet with a hole and the first tire will not pick up the magnet. What else could be wrong or what could I do?
Old Dec 16, 2022 | 01:58 PM
MetalMan2's Avatar
MetalMan2
To clarify, are any sensors programmed to the car? (you only mentioned the first one not triggering)
Do you know which sensors were installed? Some of the more modern sensors don't use a magnet to program, but will use a different trigger tool like this:
Amazon Amazon
This is the tool I bought to trigger the TPMS sensors recently installed on my 2001 Z06. Should mention that I'm not saying this will solve your problem, just using it as a discussion point.
Old Dec 16, 2022 | 04:39 PM
JPoss's Avatar
JPoss
I’m not sure what other sensors could be programmed to the car like the TPMS. To my knowledge these are ACDelco, still metal. The tire shop had a snap on computer that worked similar to the one you linked and it didn’t work, all it said was use magnet.
Old Dec 16, 2022 | 06:55 PM
MetalMan2's Avatar
MetalMan2
I meant of the 4 TPMS sensors, did any of them program to the car? It kinda sounded like the 1st one didn't program, and subsequently you stopped and didn't try programming the rest of the sensors.
Old Dec 16, 2022 | 07:35 PM
spfautsch's Avatar
spfautsch
That's what the tool will tell the operator if the sensors aren't triggered. It doesn't mean anything except that it sent the 120khz trigger signal but didn't receive a response from any sensor.
You don't mention what year your car is, and if TPMS worked prior to this. Give some history on the car, because swapping the 01-04 RFA module into older C5s became a popular mod when the older style sensors became hard to get.
You need to ask whoever installed them what exactly was installed - part #, pictures would be helpful. The ACDelco sensors for the 97-00 cars are very hard to get and expensive so I would speculate they installed something else. Also, I never trust what people tell me they did if I didn't see it happen in person.
Old Dec 17, 2022 | 01:22 PM
JPoss's Avatar
JPoss
2003 and the TPMS went from working to to not reading to not working. The receipt didn’t say what the part numbers were. Yes after the front driver side didn’t work I stopped, I was under the impression that these go in order and you can’t program the passenger side till the driver side is programmed.
Old Dec 17, 2022 | 01:39 PM
feeder82's Avatar
feeder82
Did you have the DIC in tire training mode?
Old Dec 17, 2022 | 01:50 PM
spfautsch's Avatar
spfautsch
The learn process does need to go in order to get the the correct sensors associated to the correct positions in the RFA, but what metalman2 was thinking is maybe one or more of the other sensors does work and possibly you got one that's bad. Maybe try learning the left rear to see if it responds to a tool and / or a magnet. It's closest to the RFA so it's signal should be strongest.
Honestly, if none of them respond to a magnet or TPMS trigger tool, if you bought these installed you should be talking up the person / company that sold them to you.
This is why I recommend everyone train / relearn new sensors to the car before installation so you know they work before they're inside the tire pressure envelope and you have to break the bead to get back at them.
Edit: just curious, the tire shop that had the snap-on tool - were they the ones that sold them to you?
Last edited by spfautsch; Dec 17, 2022 at 02:50 PM. Reason: Got right and left mixed up
Old Dec 17, 2022 | 02:49 PM
spfautsch's Avatar
spfautsch
One other ? did this happen gradually - i.e. did one tire at a time stop reading over a long period of time? Or all of a sudden?
Old Dec 17, 2022 | 07:18 PM
JPoss's Avatar
JPoss
They did go out gradually where they were reading and then I wound get hash marks if I pulled them up to nothing showing. The tire shop got them from another parts store.
Old Dec 17, 2022 | 08:23 PM
spfautsch's Avatar
spfautsch
Going out on a limb here but it sounds like it's the tire shop's problem - seems like they got you the wrong sensors. There's nothing special about the 01-04 Y-body TPMS system and there's no need to interface to the ALDL or clone sensor IDs or anything like that. No need for a "dealer" tool either. All you need is 4 compatible sensors that are configured to transmit on 315mhz using FSK modulation with a pressure PID and checksum. Initiate relearn from the DIC and trigger them in sequence. If a magnet doesn't work try a TPMS trigger tool. Print this out and show it to them.
MetalMan2 has a part # for some new / modern, pre-programmed sensors that will work for your application and possibly cheaper than what the tire shop sold you. You will need a TPMS tool to trigger them during relearn.
To Tpms
