Door lock problem
Old Dec 17, 2022 | 04:29 PM
acefominC5's Avatar
acefominC5
Default Door lock problem
Hello Everybody
My drivers side door lock has been becoming hard to open. It used to be very crisp & now I have to wiggle the key in order to be able to unlock the door. Look at the attached video. What is the fix?
File Type: mov
Old Dec 17, 2022 | 07:29 PM
mmartinez's Avatar
mmartinez
I would try a spray lubricant in the key hole, could be the tumblers in the key cylinder.
Old Dec 17, 2022 | 11:19 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^^ side note but are your key fobs not working?
Old Dec 19, 2022 | 11:02 AM
acefominC5's Avatar
acefominC5
Never bothered using them I prefer the key
Old Dec 19, 2022 | 01:10 PM
grinder11's Avatar
grinder11
If you have a 2000-2004, the passenger side has no exterior lock. The only way that side gets much "exercise" is thru the FOB. My .02. I do support using the key occasionally. In the salt belt, a little lube, and occasional key insertion, will keep the insides working. I've heard stories of the mechanisms seizing up from non use, especially the trunks/tailgates, which the C5s dont have, of course.......
To Door lock problem
