Reduce Engine Power
Old Dec 20, 2022 | 06:37 PM
Rasj649's Avatar
Rasj649
Cruising
Default Reduce Engine Power
Noticed tonight as i was backing into the garage gauges started to malfunction and dash said reduce engine power for like 10 seconds and then everything went back to normal then it did it again like on and off any ideas what is causing this ?
Old Dec 20, 2022 | 06:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With a scan tool checking for DTC’s may help…REP can be caused by a few things…TPS, APP sensors…I’ve seen MAF issues causing this too.
Old Dec 21, 2022 | 06:41 PM
Rasj649's Avatar
Rasj649
Cruising
1.Tried to check codes but DTC says no comm
2. i checked my battery i bought it last week it has 12.5 volts but 0 CCA car starts as normal though
3. i used a Tech 2 scan tool and under the BCM i got code U1016 and U1096 as for the PCM i got code P0650
4. while i was using the scan tool it kept losing communication with the car as well as the reduce engine power goes off and on every 10 seconds or so
Old Dec 21, 2022 | 07:13 PM
C5 Diag's Avatar
C5 Diag
Don't know what you mean by "battery has 12.5 volts but 0 CCA" ???...I think 1016 and 1096 is loss of comm with PCM and BCM...if a ground or 12 volts shows up on the single wire Class 2 data line you will not be able to communicate with the car at all...you can start by checking the powers and grounds on the PCM and BCM.
Old Dec 21, 2022 | 07:24 PM
Rasj649's Avatar
Rasj649
Cruising
i checked the battery with a battery tester it came up 12.5 volts and 0 cold cranking amps but the car starts up as normal
Old Dec 22, 2022 | 03:34 PM
Ortegb01's Avatar
Ortegb01
4th Gear
That just happened to me as I fixed the abs on my 2000. It turned out to be the connection on the right side of
the throttle body assembly. Not sure if that can help.
To Reduce Engine Power
