headlight
Old Dec 23, 2022 | 09:46 AM
yellow2007's Avatar
yellow2007
Default headlight
I'm still learning the ins and outs of my recently purchased C5. One thing I noticed is when I turn the headlight switch to the first detent, my headlights pop up. Shouldn't they remain closed until I move the switch to headlamp?????
Old Dec 23, 2022 | 10:12 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I believe that's a symptom of the gears going bad. It's been a while since I dug into that issue but I seem to remember that was a side effect.
You can get brass gears and put them in your 20yr old motor housings or you can press the easy button and get new motors which come with new gears to last you another 20yrs. I've tried both methods and while a metal gear can last a long time, the motors themselves are still old and can exhibit their own problems (mine did)
Putting in brand new motors made the headlights pop up quietly and travel smoothly just like a new car
Old Dec 23, 2022 | 10:24 AM
yellow2007's Avatar
yellow2007
Funny you should mention that. I'm bringing it to my local Corvette shop in two weeks to replace the gears because the pass side continues to run on for a few seconds. Since this is going to be a weekend only driver and will rarely see nightime I'll stick with just the gears.
Thanks JDM!!!!!!!
Old Dec 23, 2022 | 11:41 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Yep, related to the gears failing.
Old Dec 23, 2022 | 11:48 AM
jackthelad's Avatar
jackthelad
Not so sure about it being the gears. When the switch is moved to the headlight setting, that's the point at which the motors to raise the lights get power applied And they don't go down until you turn all the lights off - again a shot of power is needed to bring them down.
Old Dec 23, 2022 | 12:31 PM
jcgunn's Avatar
jcgunn
Check your OPTIONS for the Twilight Sentinel settings and make sure it is OFF
Old Dec 23, 2022 | 01:57 PM
DW600RR's Avatar
DW600RR
Can't speak for the C5, but I can say that's exactly what the 1995 Trans Am I had decades ago did when the headlight gears were going bad.
Old Dec 23, 2022 | 02:38 PM
c5arlen's Avatar
c5arlen
Is replacement of the said motor and its labor cost as extravagant as paying someone to do fabricate a replacement cheap-*** GM plastic gear... How much is this tariff gonna be?
Old Dec 23, 2022 | 06:37 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Nope
$40 bucks each. R & R is free. I swapped mine three years ago and actually bought another pair of motors to keep for the shelf when these ones go in in 17 years
https://www.ebay.com/itm/2x-Headligh...edirect=mobile
Old Dec 24, 2022 | 07:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
We went around and around with this topic back in the day. I was younger and more hot headed back then
Here's a fun discussion on the headlights popping up with the first click as a symptom of bad gears
https://www.corvetteforum.com/forums...round-2-a.html
Old Dec 3, 2023 | 11:50 PM
CADbrian's Avatar
CADbrian
When these cars were brand new did the buckets open and close in perfect unison without any delay between the two, or was there a slight delay?
Old Dec 4, 2023 | 12:18 AM
MosEspa's Avatar
MosEspa
My (current) 2000 I have replaced the driver side motor because it was broken and they both come up / down at the same time.
The 2001 I had the passenger side lagged a bit behind on up and down, but they worked fine. That one had a ton of electrical issues though which is partly why I got rid of it.
Old Dec 4, 2023 | 12:43 AM
Choreo's Avatar
Choreo
I bought my 2001 new in 2000. About year 3, the gear stripped on the right side making a terrible noise. They replaced it under warranty. A couple years later I swapped my stock plastic headlights for the all metal and glass GM Euro versions (much heavier), and yet have not had a single issue since (on borrowed time I am sure). What is amazing is that I drive almost exclusively at night (every night) and that left motor has been going 23 years!
Both my lights have always moved in unison.
Old Dec 4, 2023 | 02:47 AM
Moved to C5 Tech.
To headlight
