drivers side auto lock
Old Dec 31, 2022 | 08:17 AM
sargedel's Avatar
sargedel
Default drivers side auto lock
Good morning and Happy New Year to all,
My c5 2001 drivers side door lock does not open with either the key farb or lock on the door, however the passenger side does?
What can I check ?
Thank you
Sargedel
Old Dec 31, 2022 | 12:56 PM
bc6152's Avatar
bc6152
I had this issue with the driver's door lock. However using the key in the lock would work but not the remote. Passenger door was OK. Replacing the relays inside the door on the relay board fixed it. About $50.00. GOOD LUCK!
Old Dec 31, 2022 | 01:09 PM
_zebra's Avatar
_zebra
agree - it sounds like a power issue to the actuator. that's why you have a key hole in the door until you get this fixed (which i exclusively use anyway).
Old Dec 31, 2022 | 05:30 PM
sargedel's Avatar
sargedel
Thank you !
Old Dec 31, 2022 | 06:13 PM
bc6152's Avatar
bc6152
Originally Posted by sargedel
Thank you !
I removed the door panel and the relay board attached inside, then sent it to a guy in Maryland. He replaced ALL the relays (3) - Turnaround was two days... GOOD LUCK Amigo...
Old Jan 1, 2023 | 12:46 AM
Moved to C5 Tech.
Old Jan 1, 2023 | 09:19 AM
sargedel's Avatar
sargedel
Thank you! Do you have the information on the guy in Maryland I would appreciate it ??
Old Jan 1, 2023 | 10:15 AM
bc6152's Avatar
bc6152
https://www.ebay.com/str/autoclockrepair
To drivers side auto lock
