C5 z06
Old Jan 1, 2023 | 08:26 PM
davidshaffer5854's Avatar
davidshaffer5854
2nd Gear
Default C5 z06
I fixed the HUD. It worked. I shut the car off. I secured the HUD. But before I put it all back together, I checked it one more time. The lights on the instrument panel didn’t come on, nor did the HUD work. The radio and HVAC lights work as do the courtesy lights. Yes, I checked the dimmer switch and tail lights. Any other suggestions?
Old Jan 1, 2023 | 08:34 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, David, from Hickory, and congratulations on your C5!
I would suggest asking this question in the C5 Tech section at: https://www.corvetteforum.com/forums...s-1997-2004-2/ You will find lots of great members and helpful info there.
This is primarily just a “Hello” section.
Best wishes for an easy and inexpensive fix.
Old Jan 1, 2023 | 08:38 PM
Moved this thread to the C5 Tech section for comment.
To C5 z06
