auto trans shift
Old Jan 2, 2023 | 02:22 PM
alcoed's Avatar
alcoed
Default auto trans shift
Need help with a auto trans concern.
While on the freeway going a steady 75/80 mph, the trans did a erratic downshift to third gear. I could not find fourth all the way way home. Had several stops and all other gears performed as normal. A week ago I dropped the pan to repair a leaky pan gasket and the fluid still looked clear red and the pan was mostly clean. Cannot detect any slippage in any other gear. Any thoughts would be appreciated. Vehicle has always be taken care of and has 103k.
Old Jan 2, 2023 | 04:15 PM
Fast one's Avatar
Fast one
Did you check the fluid to see if it's low now?
Old Jan 2, 2023 | 04:20 PM
alcoed's Avatar
alcoed
No I haven't, but I will.
Old Jan 2, 2023 | 07:10 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Might have a transmission tune to change the shift points.
Old Jan 3, 2023 | 11:24 AM
JCMDoug's Avatar
JCMDoug
Here is a strange idea, lets say your shift cable is going bad and as it's eating it's self to a point that it has move into 3 gear at the transmission when in drive.
Or you have a new cable that was not installed correctly and when its in Drive at the transmission its in-between Drive and 3rd.
from what I understand when in 3rd the car will downshift/upshift like normal with 3rd as the top gear.
Old Jan 3, 2023 | 11:37 AM
alcoed's Avatar
alcoed
To confuse situation more, drove to work this morning, the shift was normal every time.
Old Jan 3, 2023 | 11:54 AM
JCMDoug's Avatar
JCMDoug
Well good it's acting normal again, it could have been a fluke.
Do you know if the cable has ever been replaced, I saw a few posts about it being a problem so I changed mine when I changed the rear diff from 2.73 to 3.15
Another thing to consider old dirty filter and slightly low fluid level. until it happens again keep driving it.
side note: A new GM shift cable is 70.99 at rockauto you could get one and toss it in the trunk, when they break it's never near an auto part store and most places will have to order it.
Old Jan 3, 2023 | 12:39 PM
Elektro's Avatar
Elektro
agree to check the fluid level, it needs to be done at a specific temperature on the dash and with the engine running so look up the specific procedure.
It probably heated enough on the highway to open the tstat and either there was air in the cooler because it was not filled properly or (unlikely) the cooler has a leak.
Old Jan 3, 2023 | 06:03 PM
alcoed's Avatar
alcoed
Well trans shifts as intended to and from work. Gonna visit a local trusted tranny shop to get the fluid level checked and maybe a pressure check. Kinda lost confidence till I find the cause. Don't want to get stuck somewhere.
Old Jan 4, 2023 | 02:23 AM
Moved to C5 Tech.
Old Jan 4, 2023 | 11:23 AM
TexasRedRaider's Avatar
TexasRedRaider
If fluid is good, sounds like the 3/4 clutch pack is going or gone. Very common on higher mile 4L60Es.
Old Jan 4, 2023 | 11:25 AM
Kingtal0n's Avatar
Kingtal0n
Wait- you dropped the pan, then you didn't check the fluid level after re-filling the pan?
Old Jan 4, 2023 | 11:44 AM
alcoed's Avatar
alcoed
that was my first thought, but 3-4 clutch is also for 3rd and 3rd gear is fine. Also when pan was pulled, fluid clear and bottom of pan was clean with no wear or metal residue. Trouble is now there are no shift concerns for the last two days of driving.
Old Jan 4, 2023 | 12:21 PM
alcoed's Avatar
alcoed
yes, a couple of times
Old Jan 5, 2023 | 07:19 AM
alcoed's Avatar
alcoed
Well sir I believe you hit the nail on the head. Yesterday I had a hard time finding reverse. The gear shift is very sloppy. I ordered a new cable to correct the probably worn out bushings. But today I found that C@S Corvettes offer replacement cable bushings for 30 bucks. Gonna go that route. Don't have to pull exhaust, belly pan etc. That's the way to go. Thanks for your thoughts, I owe you!
Old Jan 5, 2023 | 09:58 AM
DWAVette's Avatar
DWAVette
My lower bushing went without any noticeable change in the shifting. It would be great if have some advance notice like that for yours. I would certainly change the lower one. From what I understand, the heat kills the plastic.
I visited Lyle at C&S when I was in the Tampa area on a business trip last year. He is very knowledgeable, helpful, and very friendly. He warned me my shift cable bushings would be failing soon on my 76,000 mile 99. I picked up a set from him while I was there and tossed them in the glove box - thought no more about it.
About a month later, the lower bushing disintegrated and left me at my office. Fortunately, I was able to jack up the car, zip tie the lower cable to the shifter well enough to make two shifts: In reverse, then drive. I was able to drive it home where I changed the lower bushing the next day. Still trying to find time to change the upper one. I know, I know….
To auto trans shift
