I am looking for mechanical advice. I was pulling out of an event one day and my clutch pedal stuck. I immediately smelt clutch burning smell. I immediately engaged the clutch and was able to go about my way and have been able to drive the car on a few trips since. I often will get a clutch smell and I'm not even driving the car hard and or riding the clutch. I have good pull and engagement when using the clutch pedal and such. I am wondering if this might be the beginning of needing something replaced like the slave cylinder and or whatever else is in the components of the clutch and trans. I don't run the car hard and if I do it's usually short and sweet. Third to fourth gear. I need the car to last and I am one who tries to head things off and take care of my vehicles. Any advice or mechanical know is appreciated.
Hey Chris, how many miles on your current clutch? What does the clutch fluid look like in the reservoir? Is it clear or cloudy and when was the last time it was flushed and fluid replaced?
Sometimes you get lucky and replacing the fluid is all it needs or it will buy you some time. And sometimes the clutch or components are too far gone and fluid change won't matter. You'll need a new one.
I have just basically turned 49k, so I imagine the clutch has that many miles on it. And from my understanding all fluids were changed about 2k before I got it to include the clutch fluid.
Chris, need you to personally check and see if the clutch fluid is clear or cloudy, dark, etc? It’s harder to change than other fluids, so it’s possible that was not changed along with the others. Best to unscrew the cap and look at the fluid.
