On my C5 the drivers side headlight goes down then pops up half way???? I took it apart and saw that the rubber bumper was badly damaged - I replaced it and the problem continues. The new bumper is now partially chewed up - suggestion would be appreciated Thx Max
there is a company that make stronger replacement bumpers and a kit of tiny washers that you may use to move the bumper arms over a bit. IRRC it comes with directions. One thing I learned is to unscrew and remove the lid that goes over the top of the light. This will give you enough room to get your hands in and install the washers to move he arms over a tick. If you search the forum you should find them
Do you by chance have the instructions for this kit? I wanna see if I can't just find the washers myself at a local hardware store and do it myself.
Just got the kit and instructions - how can i send it to you Thx Max
