lots of codes
Old Nov 12, 2011 | 08:14 PM
Hayekfan's Avatar
Hayekfan
Default lots of codes
Looking to buy a 2000 coupe, mt, and pulled the codes using the car's system. This is new to me, but it seemed like a lot of codes.
1040, 0338, 2282,2283,2284,2285,1064, dreaded 1255,, 1096, 1016, and 2120.
I'm guessing the ABS is cooked. The BCM, I don't know. Also, why all the battery codes?
Is this car trouble to the tune of a couple of thousand dollars?
Wayne
Old Nov 12, 2011 | 08:45 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
If you can, I would clear the codes out and take it for nice a test drive. Then check the codes once you get back.
Those codes might have been in the history for a while...
Old Nov 12, 2011 | 08:53 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This is an excellent suggestion - When the PCM is connected too you get a lot of 1096 and 1016 codes etc.
It is also possible the owner never ever cleared the codes before either, might be a huge compilation of codes -
Do you also have the "Letter" to the codes ex: B, P SCM, LDCM, HVAC etc.? this will really help in identifying the actual problems
Here is the list of codes:
http://www.stengel.net/diccodes.htm
Thanks,Matt
Old Nov 12, 2011 | 09:03 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
A Must Do!
Old Nov 13, 2011 | 12:10 AM
routeman007's Avatar
routeman007
A quick-little how to,,, If you will please...Thank You!
Old Nov 13, 2011 | 02:45 AM
DeeGee's Avatar
DeeGee
When posting the codes you need to post the whole code, eg C1214HC. A history code means that the fault occurred but has cleared and the car has run through a number of ignition cycles without the fault present.
U codes can be posted by a simple power glitch and may not be significant.
Do any of the faults have a "C" as a suffix because those are the ones you need to check out.
Old Nov 13, 2011 | 02:46 AM
DeeGee's Avatar
DeeGee
Check the link that Matt posted. It starts with how to pull and reset the codes.
Old Nov 13, 2011 | 09:07 AM
routeman007
Thank You!
Old Nov 13, 2011 | 09:43 AM
Jet-Jock's Avatar
Jet-Jock
Anytime a battery voltage drops below a specified value on the main bus you will get communication errors and associated module errors.
If the battery recently had issues that would be a clue.
Follow the suggestion to clear the codes and take it for a test drive then review what codes appear.
BTW, it is helpful if you look through the list and write down ahead of time, the modules so as each one displays you just have to jot down the codes for each module and not worry about jotting down which module it was.
Powertrain Control Module (PCM)
Traction Control System (TCS), which combines traction control, ABS and, on cars built after 1997, the optional Active Handling System
Real Time Damping (RTD)
Body Control Module (BCM)
Instrument Panel Cluster (IPC)
Radio
Heating-ventilation-air conditioning (HVAC)
Left Door Control Module (LDCM)
Right Door Control Module (RDCM)
Seat Control Module (SCM)
Remote Function Actuation (RFA).
Old Nov 13, 2011 | 10:58 AM
VETJAZZ's Avatar
VETJAZZ
Radio
Jet-Jock - Thanks for this info!
Old Nov 13, 2011 | 11:49 AM
Kmcoldcars's Avatar
Kmcoldcars
When you take it for a test drive after clearing the codes do not go for a 10 minute drive around the block. Get it out and drive it for an hour or so, both in the city and on the highway.
Old Nov 13, 2011 | 08:19 PM
Hayekfan's Avatar
Hayekfan
Thanks for the replies, they were helpful. I'm doing the deal and getting the Vette later this week. I'll post pictures after I get it home. 2000 Coupe, 33,000 miles, 6 sp, red, two tops, extra set of new stock rims. Clean Carfax, 8k miles by present owner in last 6 years.
Wayne
Old Nov 13, 2011 | 10:18 PM
Xx_Black-out
Wayne
Sounds like a nice car!
Old Nov 14, 2011 | 11:13 AM
kenc5's Avatar
kenc5
My car sat for two weeks and I took it out. Codes up the @ss. Shocks inoperative, reduced power, low fuel, no air cond, low tire pressure...
Charged battery and it got well.
Old Jan 19, 2023 | 12:37 PM
Janbolo's Avatar
Janbolo
2nd Gear
Thank you for this great reference information! I am a happy owner of a new to me 1998 C5.
Very happy to have found the Service Manual on this amazing site, thanks to all those sharing THE KNOWLEDGE, awesome!
First update for our C5 is an Optima redtop 78 battery.
Old Jan 19, 2023 | 01:13 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum! Enjoy your C5!
Don't forget to SAVE THE WAVE!!
Old Jan 19, 2023 | 05:48 PM
killain's Avatar
killain
Oldtimer
This is the best advice, but only if you can, I bought a 03 last year, and when I went to revel the DTC, I had about 24, but I was told to erase them and then check again, (Using the C5's own internal reader) and once I did that I took for a 15 minute trip and when I got back, again I checked the codes and only 2 remained !
Old Jan 20, 2023 | 12:59 AM
Even though an old thread, it is best placed in the C5 Tech section.
Old Jan 24, 2023 | 12:40 PM
Janbolo's Avatar
Janbolo
2nd Gear
Thanks for the welcome MWWarlord!
I love waves and the ocean! Just returned from a top down drive from Albany to the beach at Lincoln City and Newport, then home on a clear sunny day.
How do I "SAVE THE WAVE!!"?
To lots of codes
