If I don't get the car thoroughly warmed up code P0153 shows up. Just intermittent so I'm going to replace my Oxy sensors and cross my fingers. What's the go to replacement? And just as important, what units to AVOID. '03 Z, 495 HP LS3 crate, mostly track use. TIA!
Last time i changed OS with boush was 12yrs ago and still working but quality went to **** no matter which one u go with. So take ur pick with all the suggestion the are going to show there face on who's the best. Not says boush is the best but i got lucky. Next time start car they might be bad.
When I had a bad O2 heater circuit and I could not get an AC Delco I went with a Delphi O2 sensor…no good…3 Bosch sensors…no good…went with a Denso and this one worked…hope you guess right.
