HVAC No Comms
Old Mar 10, 2023 | 10:20 PM
sdcdubv's Avatar
sdcdubv
Cruising
Originally Posted by C5 Diag
Yes, let’s give the HVAC module a good power source !!…didn’t you say the module is definitely good ??
Yes the module is good.
Old Mar 12, 2023 | 06:53 AM
oelarse's Avatar
oelarse
As Rob mention above use the T-pin and do some more measurements :
Disconnected HVAC plug:
  • Measure ground path quality (resistance -ohm ) between a chassis ground and C1 and D1
  • Measure Voltage between battery negative and these pins : C5, C10, C12, C16
    Connect the HVAC plug and measure the same voltages again with module
    May Rob has some more info/advice to add ?
Hopefully these measurement can give some more info .
