Automatic shift cable guide
Old Jan 18, 2023 | 08:55 AM
MSOH's Avatar
MSOH
Veteran: National Guard
Default Automatic shift cable guide
So, I was removing my shifter assemble the other evening to replace the broken indicator and add a LED bulb, and while I was trying to gently pull up on the assembly I hear a loud snap. Yep, the cable guide broke. Is this cable still usable or did I just add to my list of thing to do by needing to replace the cable?
Old Jan 19, 2023 | 08:42 AM
whbrennan's Avatar
whbrennan
Mine broke when I replaced the grommet when I got stuck at work. I went to the local Chevy dealer to buy a new cable, of course they didn't have any in stock and said there was two part numbers in their system. I even gave them my VIN number and they couldn't tell me which one was the right one, so I ended up buying the one that was listed on Rock Auto for my 2003. Of course, after I pulled the mid pipe and tunnel plate off to replace the cable, I had the wrong one. Apparently, halfway through the 2003 model year production, they decided to change the design. So I ended up Macgyvering my cable with some safety wire since I couldn't find a cable locally that day. I ended up buying a new cable off of Ebay and had it installed when I got my transmission overhauled about a year later.
Old Jan 22, 2023 | 06:56 PM
MSOH's Avatar
MSOH
I like that fix! Very ingenious and better than zip ties! I may end up doing the same thing myself
To Automatic shift cable guide
