2004 ac
Old Jan 23, 2023 | 02:18 PM
Cstawa's Avatar
Cstawa
Default 2004 ac
My AC is not working I was told it was the Actuators, but If I reset the code the AC will work perfect for a few minute but then blow hot. If I shut of the car and resent the code again you can hear the actuators moving, restart the car and it work for a few minutes only. Any thoughts.
Old Jan 23, 2023 | 02:56 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Sounds like you need new actuators to me.
If you reset the actuators, they work until they don't, requiring a new reset so they work until they don't. Does that sound right? If so, you are in a loop and I'd say that you need to swap them out.
Old Jan 23, 2023 | 04:26 PM
wayne100's Avatar
wayne100
first thing to try is have it evacuated and recharged, alot cheaper than anything else to try
Old Jan 23, 2023 | 11:28 PM
bookyoh's Avatar
bookyoh
I am unclear by what you mean by blow hot. With the a/c off and the blower fan running with the temperature set to full cold, the air out the vents should just be a few degrees warmer than the ambient air temperture. If it is blowing much warmer than ambient, then you have a blend door problem. If it is blowing a little above ambient and does not get cold with the a/c on, you likely have a refrigerant side problem.
Old Jan 24, 2023 | 02:55 PM
Cstawa's Avatar
Cstawa
With AC on after reset code it will blow cold after a few min it starts blowing hot
Cstawa's Avatar
Cstawa
Yes I tried that
Old Jan 24, 2023 | 02:56 PM
Cstawa's Avatar
Cstawa
Yes that what's happening
To 2004 ac
