how to replace
Old Jan 28, 2023 | 07:18 PM
D C's Avatar
D C
USMC (retired)
Default how to replace
What is the correct part number of the engine fuse box for a 2004 and how do you replace one?
for relay 43 and 45, does the notch go on the top or on the bottom?
Old Jan 30, 2023 | 05:47 PM
D C's Avatar
D C
USMC (retired)
How do you replace the engine fuse box on a 2004 corvette? is it just removing the nut and the tabs on each side and pull up?
Old Jan 30, 2023 | 06:36 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Why are you replacing your fusebox ??…if you want the correct part number I’d stop by your local GM dealership and ask the parts guy…a relay if a 4 blade can go in either direction and work.
Old Jan 30, 2023 | 08:12 PM
don37's Avatar
don37
Veteran: Canadian Forces
correct. gm part# 12193837
Old Jan 31, 2023 | 06:46 PM
D C's Avatar
D C
USMC (retired)
Thank you for the response but I believe that part number is for the interior fuse box, not the engine bay fuse box.
Old Jan 31, 2023 | 06:51 PM
D C's Avatar
D C
USMC (retired)
The reason for replacing is that the plastic had melted from relay 43 burning up
Old Feb 5, 2023 | 06:04 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Plenty of recyclers with websites, or posts for sale on FB and here of part-outs which would have it.
To how to replace
