Engine Noise
Old Jan 28, 2023 | 08:01 PM
Willows's Avatar
Willows
Default Engine Noise
Getting a ticking noise from the engine of a 99 that’s the same tempo as a valve that’s sticking. I’ve read it could be other things and not a serious or costly fix. I tried to search it but felt best asking directly.
I realize this information isn’t very detailed. Was looking to buy and want to get some info before I go back.
What should I be looking for?
Old Jan 28, 2023 | 08:38 PM
mmartinez's Avatar
mmartinez
Only way to really tell what is going on is to remove valve cover and inspect, any advice about what that noise would just be a guessing game.
Old Jan 28, 2023 | 08:56 PM
Willows's Avatar
Willows
That’s what I was thinking tbh. I know the info is too vague. How expensive is it to do a valve job in a shop? Been a while since I’ve needed one.
Old Jan 28, 2023 | 11:55 PM
jim993's Avatar
jim993
What are the miles on the engine and what are the codes, if any?
LS engines are notorious for all kinds of noise, especially when cold. The common diagnosis is piston slap but the noise could also be valve related. Piston slap noise usually goes away when the engine warms up but valve noises typically do not. Piston slap noise is usually not a worry because LS engines ordinarily last an extraordinary length of time regardless. Unless boosted.
My theory is that aluminum block engines are noisier than iron block engines because the aluminum expands and contracts more than iron from temperature changes and aluminum transmits vibration more than iron at the frequencies we hear.
You have been advised to remove valve covers and see what you can see. Look for any rocker that is not tight against the valve stem and or broken valve springs. A loose rocker could be because of a broken valve spring, a rocker trunnion failing or, very unlikely, a stuck valve.
Old Jan 29, 2023 | 06:18 AM
Willows's Avatar
Willows
Thanks. It’s a 99 with 94,000 miles. I’ll check everything when I get back up there. I knew it could be a few things but not sure what exactly. This was a big help.
Old Jan 29, 2023 | 10:09 AM
jim993's Avatar
jim993
I forgot to mention using an automotive stethoscope to help pinpoint noise location.
$11 on Amazon.
http://www.amazon.com/HARDK-Automoti...xpY2s9dHJ1ZQ==
Old Jan 29, 2023 | 11:17 AM
Willows's Avatar
Willows
Thanks again!!
Hate to admit how much of a greenhorn I am but…
Old Jan 29, 2023 | 11:59 AM
666lisa's Avatar
666lisa
U might get better advise if u can get a video. Just go through youtube copy/past. It could be as eazy as a exhaust leak.
Old Jan 29, 2023 | 01:03 PM
Willows's Avatar
Willows
Originally Posted by 666lisa
U might get better advice if u can get a video. Just go through youtube copy/past. It could be as eazy as an exhaust leak.
WhenI get it home I’ll do some work on it. A couple of repairs can be expected.
Was trying to figure this out before I bought it, and was trying to avoid a mistake. I’ll fix whatever it is.
Old Jan 29, 2023 | 07:00 PM
DWAVette's Avatar
DWAVette
How is your oil pressure?
Old Jan 29, 2023 | 09:21 PM
Willows's Avatar
Willows
I didn’t check when I was there and won’t see the car again until Tuesday. When I get it home I’ll go through everything.
Old Feb 10, 2023 | 11:18 PM
Willows's Avatar
Willows
it’s at 40 when I’m going 70 and is 30 at idle
Old Feb 10, 2023 | 11:21 PM
Willows's Avatar
Willows
I ran it for a couple of hours yesterday and it was still there. Going to a shop Wednesday but would like to have an idea before they tell me something else
Old Feb 11, 2023 | 12:22 PM
grinder11's Avatar
grinder11
Thanks again!!
I doubt very seriously it's a stuck valve if all has been well for 94,000 miles. But it could be a slightly bent valve from a PO overrev. My guess is you're probably OK, because as Jim said, LS engines can be a bit noisy. But I'd check as has been posted.
Old Feb 11, 2023 | 01:43 PM
Willows's Avatar
Willows
thanks. I’m going to see a mechanic Tuesday and see what he says. I always worry about getting a snow job from them but they’re capable.
maybe the dealership can give me a more trustworthy quote.
https://www.fairwayautomotive.com/
Old Feb 11, 2023 | 01:49 PM
666lisa's Avatar
666lisa
Wow thats opposite. U ever stealership.
Old Feb 11, 2023 | 03:53 PM
Willows's Avatar
Willows
that’s going to turn out to be some valuable advice, thanks!!
Old Feb 18, 2023 | 11:20 AM
Willows's Avatar
Willows
So my shade tree friends all said it sounded like a valve problem, and that’s what I was worried about.
found a very good shop, the manager built a c6 and they work on all classic cars. Gave a test ride and looked at the engine. Come to find out the noise is the fuel injectors. He said the engine is in excellent condition. What a relief. Went for a long ride to celebrate.
thanks for the advice and reply’s everyone, greatly appreciated!!
To Engine Noise
