Is Vacuum Necessary when bleeding Power Steering?
Old Jan 12, 2003 | 09:15 PM
corvette_karl's Avatar
corvette_karl
Default Is Vacuum Necessary when bleeding Power Steering?
I'm about to install a Power Steering cooler in my C5 and was reviewing the Tech manual and one step of the bleeding process is to hook up a vacuum pump and put a vacuum on the system for a specified time.
My question is: Is this necessary, or is it just to verify that the system doesn't leak?
I'm not having any luck figuring out a way to put a vacuum on the system. I have the vacuum pump, but have yet to figure out a way to get a tube in there and seal the opening to the fluid resevoir.
Thanks in advance for your help!
Karl
Old Jan 12, 2003 | 09:41 PM
jmX's Avatar
jmX
Default Re: Is Vacuum Necessary when bleeding Power Steering? (corvette_karl)
I've had all those lines out a few times now and I've never had a vacuum pulled on the system. Just do the normal bleeding procedure and any air will work itself out just fine.
Old Jan 12, 2003 | 10:04 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
The air will work itself out eventually.. However, if you run the system with alot of air in it, you can damage the pump..
The GM part, which they make a big deal of, is nothing but a rubber cork with a hole in the middle and a hose inserted into the hole..
Just fill the system, and work the wheel from lock to lock without the motor running.. then check the level. Then start the motor, work the wheel back and forth two or three times, and stop the motor.. wait for the bubbles (if any) to settle down and check the level.. If okay, you should be fine.. But if the pump is noisy, do NOT run it that way for long..
Old Jan 13, 2003 | 12:12 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Is Vacuum Necessary when bleeding Power Steering? (nevrenuf)
I just pulled the pipe cooler off and put the finned cooler on then topped off the reservoir with PS fluid and took the car for a drive. You actually do not lose much fluid when making the change.
Bill
Old Jan 13, 2003 | 04:38 PM
Stu in CA's Avatar
Stu in CA
I had my system open and followed the shop manual procedure for bleeding. Lots more than three times though lock to lock, something like 20 times lock to lock with engine off and wheels in air. I did see bubbles working their way up to reservoir. Works fine after and no noise.
To Is Vacuum Necessary when bleeding Power Steering?
